Old Warn winch wiring?
Submitted: Tuesday, Oct 30, 2012 at 17:42
aussiedingo (River Rina)
G'day all, I have just bought an old Warn winch (MRV-B-7) & if someone can help me with a wiring diagram - What goes to F1, F2 & A also where does the original car battery positive 'n negative leads connect to the unit? I have done a google search & nothing there to help unless you are a member of some forums. thanks in advance,
dingo
Reply By: workhorse - Tuesday, Oct 30, 2012 at 19:15
I had an old Warn winch and contacted Warn USA. Gave them the serial numbers and they were able to tell me the month of manufacture. The information, backup and technical assistance was outstanding. they even gave me alternative sources for solenoids for my
old winch. I would suggest an email to them would give you a pleasant surprise in old fashioned backup.
497647
Reply By: Member - Tony V (NSW) - Tuesday, Oct 30, 2012 at 22:13
dingo,
found this at
Warn winch forum
You will need to register to get larger pics.
Good luck.
497654
Follow Up By: aussiedingo (River Rina) - Wednesday, Oct 31, 2012 at 07:52
Thanks Tony, I did lift these pic's yesterday from this page but small as you say, I guess I will have to register to see them full size. Thanks again, regards,
dingo
773479
Follow Up By: aussiedingo (River Rina) - Wednesday, Oct 31, 2012 at 09:36
G'day again Tony, I sent an email direct to Warn USA & received a very prompt reply with two wiring diagrams for the 2 versions of that winch, very efficient. thanks again,
dingo
773481
Reply By: Dust-Devil - Tuesday, Oct 30, 2012 at 23:11
Dude!
You didn't google anything.
I just googled - Warn MRV-B-7 - and the screen lit up like a X-mas tree with hits.
I will give you the following leads:
(1) MRV - B -7 denotes the motor model, not the winch model
(2) It is a 20 spline 6Hp motor.
Now you can figure the rest out
497656
Follow Up By: aussiedingo (River Rina) - Wednesday, Oct 31, 2012 at 07:48
thanks dude, the wiring I need to know is for the motor! The wire for the winch you idetified I know where it goes - it has a hook on the end. thanks anyway
773478
Reply By: Member - lyndon NT - Wednesday, Oct 31, 2012 at 16:24
Not much help but from memory F1 and F2 are + and - get them around the wrong way and the motor will operate in reverse. Burned out a solenoid once and had to swap them around to get the winch cable back in.
Lyndon
497683
