Road Conditions - Bingara to Narrabri NSW
Submitted: Sunday, Nov 04, 2012 at 15:51
ThreadID: 98856 Views:8009 Replies:3 FollowUps:3
Hi, can anyone give a current report on this road (total distance about 110km) for someone towing an off-road campertrailer - an Ultimate CT. Google says that it is very steep (grade of 15%) in one small section of about 750 metres with a couple of other sections of about 10%. I'm thinking it should be fine as long as it's not wet but would appreciate any detailed info. Thanks, Ian
Reply By: JAX W - Sunday, Nov 04, 2012 at 16:05
Hullo Ian
It is a great drive that is all sealed. There are some Creek crossings etc that should be slowed down for, but would likely be quite dry because of lack of rain.
I have towed our 3500+kg van both ways on this road a number of times and really enjoy the drive. We have a 200 Series Cruiser wagon.
It should not matter if the road is "wet" or not - just drive to the conditions.
I hope this helps.
Enjoy the drive.
Regards, Jack
AnswerID: 497909
Follow Up By: Member - Ian W1 (QLD) - Sunday, Nov 04, 2012 at 17:28
Great, thanks Jack. One of our maps shows it as unsealed, the other shows it sealed. My 4.2Tdi Patrol towing a 1200kg camper trailer shouldn't have any problems. When we travel to Melbourne we try and use a different route each time...the Newell is pretty boring, so this looks like a good alternative. Thanks again.
FollowupID: 773820
Reply By: Member - Kevin S (QLD) - Sunday, Nov 04, 2012 at 18:04
Ian, it's an easy tow as Jack has said. I towed a 17ft off road van with a Jackaroo 3.0L TD from Narrabri with no trouble at all. Windy and a bit narrow in places but very scenic. Don't miss the chance to see Sawn Rock in the Mt Kaputar NP. Only a short distance from the road to a day use area with facilities and a short walk to the rock.
Kevin
Kevin
2019 Mitsubishi Cross
AnswerID: 497916
Follow Up By: Member - Ian W1 (QLD) - Monday, Nov 05, 2012 at 07:21
Thanks Kevin. We'll certainly be going that way to check it out.
Ian
FollowupID: 773866
Reply By: baz&pud (Tassie) - Monday, Nov 05, 2012 at 17:23
G'day Ian,
We travelled this road a few weeks ago towing a near enough to 3 ton van, and had no problems at all, it's a great trip, enjoy.
Baz
AnswerID: 497962
Follow Up By: Member - Ian W1 (QLD) - Monday, Nov 05, 2012 at 18:55
Thanks Baz.
Safe travelling,
Cheers, Ian
FollowupID: 773914
