Manual Hubs - should I have them locked all the time
Submitted: Sunday, Nov 04, 2012 at 16:52
ThreadID: 98858 Views:3579 Replies:7 FollowUps:11
I have just bought myself a Nissan Patrol cab / chassis with manual hubs. Should these be left locked all the time or not. If they are would there be an increase in fuel consumption etc. I am not travelling on dirt all the time but every now and then curiousity gets the better of me and I just have to see what is down the end of that road. Might save me and the cook having to get out if the hubs are already locked.
Reply By: howesy - Sunday, Nov 04, 2012 at 17:24
Save fuel and leave the in the unlocked or free position. It takes 30 seconds to get out and lock em if you need to. lock them once a month for a 10 or 20 km trip just to turn it all over then free them again. I used to only lock them when the road started to look like I might need them.
AnswerID: 497915
Reply By: Motherhen - Sunday, Nov 04, 2012 at 23:15
Hi BindoonBlu
Our mechanic pointed out the amount of wear right through because we leave them engaged on our on-farm Landcruiser for convenience.
AnswerID: 497930
Follow Up By: Allan B (Member, SunCoast) - Sunday, Nov 04, 2012 at 23:49
Well the front drive is not going to wear any more than the rear drive just from being driven without power, is it?
FollowupID: 773854
Follow Up By: Motherhen - Sunday, Nov 04, 2012 at 23:54
Hi Allan
Being a totally unmechanical female i can't outline it all. He explained all that was wearing and how much more it would cost us compared to turning the hubs off when not needed. I have to believe him.
Mh
FollowupID: 773855
Follow Up By: The Bantam - Monday, Nov 05, 2012 at 00:12
If the gears, axles, unijoints and bearings are rotating they are wearing.
In fact there are types of wear that can only happen this way.
FollowupID: 773858
Follow Up By: Allan B (Member, SunCoast) - Monday, Nov 05, 2012 at 00:16
Hi Mh,
A farming wife being unmechanical? I don't believe it for a moment.
Well, maybe your mechanic is right. I was just applying simple logic...... very simple! LOL
I certainly now leave mine engaged in country where I might have need of 4WD in a hurry. Once ploughed through the sand to the barge at Inskip Point having forgotten to lock them. The barge operator was as surprised as I that I made it. And there have been other times too.......!
FollowupID: 773859
Follow Up By: Motherhen - Monday, Nov 05, 2012 at 00:16
Thanks Bantam - just as he said. You're not my mechanic are you? LOL - He is a very good mechanic :)
Mh
FollowupID: 773860
Follow Up By: Member - Bruce C (NSW) - Monday, Nov 05, 2012 at 13:42
Hi Motherhen and Allan,
If the drive is left engaged then it places strain on the drivetrain to the front and back wheels more so than normal due to diff windup.
With the front wheels disengaged this windup does not occur as it is not generated in the first instance.
This windup can be severe. I once broke the front left half axle in my 70HP 4WD tractor due to windup because I had the front drive engaged most of the time. They always let you down when you need them most. Certainly not the case any longer. It only gets selected when needed now and disengaged as soon as it is no longer needed.
The broken half axle was substantially larger and stronger than those found on a Toyota I can assure you so those stresses can be quite severe. Even if you do not break something then you are wearing something needlessly. So your mechanic was spot on Motherhen, if it is not needed disengage it for safety sake as one day your life may depend on it.
Alan,
you are right in the case of the constant 4WD but this is due to the centre diff. Anything with lockable freewheeling hubs is not so lucky as they cannot get rid of the windup unless unlocked or you drive backwards to relieve the stress buildup.
You can notice this buildup in our vehicle if you bring in 4wheel drive via the dash button and is more noticable in low range by our not being able to disengage low range to go to high range.
You probably know all this anyway Allan so if that is the case please excuse my lesson. It was offered with good intention.
Cheers, Bruce.
FollowupID: 773894
Follow Up By: Allan B (Member, SunCoast) - Monday, Nov 05, 2012 at 18:34
Thanks Bruce but simply locking the free-wheeling hubs without moving the drive selector to "4WD" does not engage the front drive to the gearbox, it is still isolated so no windup can occur. Perhaps you misunderstood some of what we were saying.
All that happens with the hubs locked is that the front wheels are now connected to the front drivetrain which is now simply idling along....spinning the components but transmitting no power and being ready to quickly engage 4WD.
Certainly, after operating in the 4WD mode and reaching firm ground it can be necessary to reverse a few metres to relieve the gear mesh and allow the 4WD to be disengaged.
Constant 4WD with a centre diff is a different matter but then they don't have lockable/freewheeling hubs so it is not an issue.
I'm sure Motherhen understands about the issues of transmission windup also.
FollowupID: 773912
Follow Up By: Member - Bruce C (NSW) - Tuesday, Nov 06, 2012 at 08:25
Thank you Allan, I am on the same page now. LOL
FollowupID: 773938
Reply By: Cravenhaven - Sunday, Nov 04, 2012 at 23:56
Leave them unlocked, unless you need them. Locking the hubs means that the wheels are then locked to the front axles/front diff/tranfer case, the result being that there is more stuff spinning so more effort required to move the vehicle, therefore more fuel usage and unnecessary wear.
cravenhaven
AnswerID: 497933
Reply By: The Bantam - Monday, Nov 05, 2012 at 00:14
Some people claim not to notice any difference.
But I can tell you that most 4wds will be smoother, quieter, accelaerate better, brake better and use less fuel with the hubs unlocked.
AnswerID: 497934
Follow Up By: Allan B (Member, SunCoast) - Monday, Nov 05, 2012 at 00:22
I certainly can notice the difference when I fling it into 4WD-Low having forgotten to lock the hubs (see above)
But you are right of course about everything spinning and being smoother etc. There is always a penalty for convenience.
FollowupID: 773862
Reply By: Peter_n_Margaret - Monday, Nov 05, 2012 at 09:43
When we bought the OKA at 330,000km it had no free wheel hubs.
I fitted them, an expense that I now regret.
I can't tell the difference in fuel consumption with them locked or unlocked and mostly we are on gravel or dirt and they are locked anyhow.
They do represent another wear point and weakness in the drive train that does not need to be there.
OKA196 Motorhome
AnswerID: 497946
Follow Up By: Allan B (Member, SunCoast) - Monday, Nov 05, 2012 at 11:37
Thanks Peter, I was feeling rather alone on this.
Is it too late to remove your hub-locks?
FollowupID: 773888
Reply By: Bazooka - Monday, Nov 05, 2012 at 15:34
I use the if-in-doubt-lock-the-hubs principle. That is, if there's a small chance I might need 4WD (wet or slippery surfaces) then I lock them. I also lock them occasionally on a long hwy run to keep everything lubricated. Next to no difference in fuel consumption probably because of momentum but I can initially feel the difference when I lock/unlock them. Obviously use means wear over time but from my own experience and what I've read elsewhere it is not a significant issue if you are running standard gear.
AnswerID: 497953
Reply By: Wilko (Parkes NSW) - Tuesday, Nov 06, 2012 at 06:53
Hi Bindoon blu.
I'd leave them unlocked and put them in every month or so to "lubricate them" I've got a new hilux and wish it had freewheeling hubs. I often had my old truck (with unlocked hubs) in 4wd low maneuvering trailers/ caravans on hard services/tar. I cant really do this with the new girl. I also used 3rd gear low range with unlocked hubs to easily go down some of the steeper hills along the great dividing range. It'd sit around 30-40kph and youd rarely have to touch the brakes.
Cheers Wilko
AnswerID: 498006
Follow Up By: Member - OnYaBike - Wednesday, Nov 07, 2012 at 22:48
Yes Wilko, I often use low range 4WD with unlocked hubs to move the boat and trailer around the yard without having to ride the clutch. Very handy.
I leave the hubs unlocked till it looks like I might need 4WD. If I haven't used 4WD for a month or so, I lock the hubs for a few km.
I once had an old (1964) Nissan and fitted lockable hubs to that. They were an innovation then.
Before that I had a 1959 ex army Series 2 Land Rover. No hubs. The front drive shaft spline and universals were forever needing attention.
FollowupID: 774066
