Problems with current model Mazda BT 50s / Ford Rangers
Submitted: Sunday, Nov 04, 2012 at 17:14
John M54
1. My car was delivered new with first and second gear being very difficult to select. It was fixed, and then 5000 km later I lost first second and reverse gear 700 km from a Mazda dealer. [It had to be trucked in] A relative of
mine has an auto and his car lost fluid from the gearbox. His also sticks in gear and shudders when changing the gears. If you have any of these warning signs [fluid loss or sticky gears]it would be wise to see your dealer.
2. My car was fitted with a canopy, racks and a wire basket. Into this basket I put a Tyre, shovel and 2.5 m square canvas canopy. [Total weight of 34 kg] Three weeks later my tub had split in 2
places. [Now 4!] Mazda are refusing warranty because they said I had too much weight on
the tub sides. I have a photo of a Mitsubishi Triton with the same setup. On the racks a sticker says not to exceed 75 kg per rack- that is 150 kg all up. ARB [and possibly others?]Manufacture a strengthening frame to compensate for this vulnerability in the Mazda tub if you are to fit the sort of gear I have. Earlier Model BT 50s do not require this. There is no warning in the manual about fitting non-Mazda accessories other than to suggest that they may not do the job. Nor is there advice regarding the maximum load that may be placed on
the tub walls.
I am asking if other people who may have experienced these difficulties [particularly the splitting of
the tub] to contact me as I am wondering whether I have some legal redress on this issue and what others have done to address the issue. Thanks for any help you can provide. John
Reply By: Legendts - Monday, Nov 05, 2012 at 21:38
John, I would say you have a good case.
If no info is on
the tub or in the handbook, or if there is and you have not exceeded it, they surely can't have a leg to stand on. I would think that if it can't take 34kgs it must be pretty weak and not fit for purpose.
My thoughts for what it's worth.
497993
Follow Up By: John M54 - Friday, Nov 09, 2012 at 20:09
Hi Again, My local 4x4 dealer has just told me of a
Ranger [ same car really] that just got back from the cape with the same problem. All he had up top in an aluminum tray was a swag. The tubs of these cars seem quite fragile John54.
774202
Follow Up By: Jefvon - Friday, Nov 09, 2012 at 21:01
John,it sounds like you might have a bit more ammunition for your argument.
I'm surprised no one else has commented here and it seems like it fits in the "not fit for purpose" basket for sure.
Cheers and good luck.
Jeff
774206
Follow Up By: John M54 - Sunday, Nov 18, 2012 at 20:17
Thanks Jeff, I'll see where it all goes. I'm sure taking this to court will make this a drawn out process!
774723
Follow Up By: Jefvon - Sunday, Nov 18, 2012 at 20:52
I wish you the very best of luck John.
774730
