Coromal Capri Pioneer XC
Submitted: Monday, Nov 05, 2012 at 17:42
ThreadID: 98875 Views:2982 Replies:4 FollowUps:1
Our caravan has a Electrolux fridge,just above the fridge is a switch which appears to turn a fan on at the back of the fridge.I have looked in the manual and cannot find why and when this switch should be on.Would appreciate your feed back as we are in the Darwin heat at the moment and anything to help the fridge would be great.
Reply By: Member - Boo Boo (NSW) - Monday, Nov 05, 2012 at 17:58
Carl
A lot of people including myself have put a computer fan near the back of the fridge to draw the hot air away and help the fridge run more efectively.
You will probably find the fan held to the outside vent by cable ties.
I have a thermostat hooked up to the fan which turns it on/off. In your case you may only have the on/off switch, therefore You should probably turn it on when you pull up for the night and only turn it off when you pack up.
Rockape may reply and show you a diagram etc which will enable you to put a thermostat in the setup to make it work automatically.
AnswerID: 497967
Follow Up By: Member -Carl R (QLD) - Monday, Nov 05, 2012 at 18:18
we are camped here for a few months so I should have the fans on during the hotter hours?
FollowupID: 773910
Reply By: Member - Boo Boo (NSW) - Monday, Nov 05, 2012 at 18:33
Carl
I would say yes with one proviso.
The fan may burn out if it is run continuously,
If you take the vent off the outside of the van can you see if there is a thermostat attached to the black pipe at the back of the fridge?
I'll see if I can find the diagram that shows the whole box and dice.
AnswerID: 497970
Reply By: Member - Boo Boo (NSW) - Monday, Nov 05, 2012 at 18:40
Carl
Have a look at this site it explains every thing.
http://www.dreampod.net/boroma/fridgefan.html
Just go to a Jaycar and get the bits you need.
AnswerID: 497972
Reply By: Lakers - Tuesday, Nov 06, 2012 at 22:36
Also in high temp areas such as in Darwin it may be a good idea to buy a wireless thermometer for the fridge... about $30 will get you one (ebay, Jaycar etc). This will enable you to manage your fridge temperature without opening the door to check how things are going. This will ensure you are not susceptible to food poisoning, or worse still, the beer gets warm. As with your fridge at home, you should manage your 'van fridge to 3 degrees.
AnswerID: 498053
