Drop slide for fridge
Submitted: Tuesday, Nov 06, 2012 at 08:34
ThreadID: 98880 Views:12487 Replies:9 FollowUps:8
G'day,
Anyone own one? Whats your thoughts? I notice in their literature, it states some transit bags can't be used? I've a 40 litre Engel, does the bag issue apply to this fridge? Also.... Does anyone know where/who does a better price than commonly seen?
Wazza.
Reply By: BJ & Reen - Tuesday, Nov 06, 2012 at 09:30
G'day wazza we have a 40 litre Engel with a transit bag in a drop slide no worries as they say best thing since sliced bread have it in the back of a 100 series on top of the draws drops down just above tail gate, cant help with price we got a package with ARB (draws drop slide luggage barrier etc)
Safe travelling Bj
AnswerID: 498012
Reply By: Member - John - Tuesday, Nov 06, 2012 at 09:32
Wazza, I have one for the 60lt engel and removed the transit bag to fit fridge. What I did do was cover fridge in foam from Clarke Rubber, silver on the outside, adhesive on the inside, 25mm thick. Seems to work well. They some times come up on fleabay cheaper than normal, or visit the shows. Hope this helps. John
John and Jan
AnswerID: 498013
Reply By: Mick O - Tuesday, Nov 06, 2012 at 11:31
Wazza,
I’ve been using a drop slide for the past 2 years or so now and they are bloody great. They have pros and cons each of which I’ve discussed in a review I did on the product and the 75 Litre Engel Combo I’m using. No problems with the Transit bags other than to make sure the top is zipped properly lest it get caught in the scissor action when lifting and closing the slide.
Have a read here.
Fridge and drop slide review
Cheers Mick
AnswerID: 498022
Reply By: Member - Scott M (NSW) - Tuesday, Nov 06, 2012 at 12:31
Got one in the canopy of my HJ47 tray for 40 ltr Engel - best thing since sliced bread.
However, they ain't cheap, (and they ain't light) !!! I tried to source a cheaper one for a while on the web and other sources - best I could get was around a $10-15 differential each way... basically they're around $570 for a DS40 and $620 for a DS60 - some throw in some accessories with the unit - but they were all around the same price - suspect same manufacturer / importer here.
AnswerID: 498024
Follow Up By: Steve M1 (NSW) - Tuesday, Nov 06, 2012 at 19:16
Spot on there Scotty - I got mine for $600 with a set of Drifta drawers. Not cheap. It's a big bugger, the 60L Engel, and heavy. Overall, happy with the drawers and $600 is about standard price for the slide. Back to your other point: I take the slider out between trips because they take a bit of room up in the back and you're right, they're heavy. S'pose they have to be solid to carry the weight of the fridge. I wouldn't buy one over a conventional slide unless you really need the drop action - but great if you do need one.
FollowupID: 773979
Follow Up By: Steve M1 (NSW) - Tuesday, Nov 06, 2012 at 19:39
btw, works perfectly ok with the bag as long as you keep things reasonably tidy
FollowupID: 773984
Reply By: Iain M - Tuesday, Nov 06, 2012 at 12:39
Wazza these slides are so good, the make camp life easy having the fridge at a level that is usable.
Mine sits east / west in my pod and the latch system couldn't cope with the extra forces applied, they supplied an upgraded version of the latch free.
Had a nut come off the mechanism, loctite could have fixed it bit I drilled and tie-wired it, no more issues.
Pricey, but aren't they all?
AnswerID: 498025
Reply By: Rainman WA - Tuesday, Nov 06, 2012 at 16:11
I also have a 40 litre Engel and have had a drop slide for a few months now, but yet to use it properly in anger. I've found that the slide handle and fridge handle interfere with each other in the locked position and as a result the slide handle doesn’t lock in properly to the plastic clip that is designed to hold it in place. Attached is a picture of my temporary fix, I added a piece of pine packing which gave the clearance needed to lock the slide handle in position.
I contacted MSA who distribute the slides and they were very helpful but none of their suggestions solved my problem and in the end they told me to drill some extra holes in the frame so the mounting bracket holding the clip could be moved forwards, hopefully giving enough room to allow the clip and handle to lock into position, but I have yet to try this. MSA took on board my issue and told me they would may need to make some design changes.
I’m also not real keen on the use of straps to hold the fridge in place, but apparently they have had problems with people over tightening turnbuckles resulting in the frame the fridge sits on distorting and so not sliding properly.
I have also yet to work out exactly how to ensure the power cable doesn’t get damaged.
I also have a Michelle’s Sacs transit bag, it just fits but I can see that it will only take a moments inattention and it will get damaged.
Despite all this I’m happy I bought it, but the cost is a bit breathtaking. You may be able to get one cheaper at the Perth 4x4 next weekend.
AnswerID: 498030
Follow Up By: Member - John - Tuesday, Nov 06, 2012 at 19:48
cable carrier video
Fleabay Item
[img]http://m4.uxcell.com/i/11d/ux_a11110200ux0146_ux_g02.jpg[img]
Rainman, I am going to trial the item in the pic to try and prevent power cable problems. Not sure if it will work or not, but worth a try.
John and Jan
FollowupID: 773988
Follow Up By: Member - John - Tuesday, Nov 06, 2012 at 19:51
cable carrier video
fleabay link
Bummer, the links didn't work..............arghhhhhhhhhhhhhhh
John and Jan
FollowupID: 773989
Follow Up By: Rainman WA - Wednesday, Nov 07, 2012 at 15:33
There was a thread about using cable carrier a couple of months ago, anyone got any pictures on how they used it as I'm interested, but just not sure how to connect it up to protect the power lead.
I presume the segments need to be large enough to pass the ends of the cable through?
FollowupID: 774036
Follow Up By: Member - Chris & Debi (QLD) - Wednesday, Nov 07, 2012 at 16:37
Hi Rainman
Do you really need to keep the handle on the fridge when in the dropslide? As a suggestion, if the handle gets in the way it would be easier to remove it, and either use the tie down brackets that come with the Engel turnbuckle kit or make some up yourself which use the same screws as the handle.
Chris
FollowupID: 774040
Follow Up By: Rainman WA - Thursday, Nov 08, 2012 at 09:52
I lift my fridge in and out quite a bit so I keep the handles on for convenience, plus you actually have to use the handles to attach the straps that come with the slide (unless you choose to bolt it permanently into position). I bought the new ARB fridge straps and bracket which seems a better set up but I’m not convinced the handles on the Engel will take too much strain on them before they start to bend. I am considering using turnbuckles and just not over tightening them to the point where the slide risks damage.
FollowupID: 774083
Follow Up By: Member - Chris & Debi (QLD) - Thursday, Nov 08, 2012 at 10:49
I know most people do, but I dont think Engel recommend using the handles to tie the fridge down. Before the drop slide I had an Engel fridge slide which comes with the turn buckles and brackets which use the handle retaining bolts.
The bracket are available separate from Engel Here but could be easily made.
The fridge slides now come with tie down straps, or mine did, but I prefer the turnbuckles as well.
FollowupID: 774090
Reply By: Peter W - Tuesday, Nov 06, 2012 at 21:40
[img]
[/img]
Hi Wazza.
I have the set up using the "original" bag on top of some EXO drawers in my LC200 GXL.
Works a treat and drops down neatly on to the back door ledge.
Here is a pic.
Can't help with price as I have had it near 2 years now.
AnswerID: 498050
Reply By: wazza200571 - Wednesday, Nov 07, 2012 at 00:16
Thanks everyone for your replies....great feedback. Away at work at the moment, so trying to talk the missus in to going to the 4x4 show, see if we can score a show special....anyone know how much companies could knock off an item of that value, say on the last day of a show? I know the wood show on the last day, there is bargains to be had!
Thats interesting about the design fault with the handles, thanks for sharing. Seems weird no-one else has mentioned it! Maybe was a bad batch....
One other question... I plan on making some drawers up, but they wont be completed by our next trip, in around 3 weeks....so if I temporarily mounted it now on some ply (attached to floor, flush), is there enough extended length to clear my tailgate I wonder?
Wazza
AnswerID: 498059
Reply By: TandCD - Wednesday, Nov 07, 2012 at 12:49
Have been looking at one for our 60l Engel and what I have seen has been impressive .
The comments of others here are very good too.
I had to query the weight of the particular one I was interested in and at 42kg it is rather weighty .Weight was confirmed.
We are going to the Perth 4wd and Adventure Show this weekend so hopefully there may be a ' show special ' that I can pick up.
Terry
AnswerID: 498085
