CANOPY FOR MAZDA BT 50
Submitted: Tuesday, Nov 06, 2012 at 22:29
ThreadID: 98891 Views:8749 Replies:6 FollowUps:15
Hi all, I am looking for a canopy for my Mazda and want one with solid panel doors on the side. Does anyone know a company or companies that make these. I know that you can get canopies with glass side doors, but like the solid look.
Thanks HarryGB
Reply By: Nomadic Navara - Tuesday, Nov 06, 2012 at 22:45
Try this one.
AnswerID: 498056
Follow Up By: Harry B2 - Saturday, Nov 17, 2012 at 20:51
Thanks Peter D, I did buy one of these, but it did not fit properly. May have to look at one with strengthening bars internally.
HarryB2
FollowupID: 774672
Reply By: Member - Phil G (SA) - Wednesday, Nov 07, 2012 at 13:40
Flexiglass have recently released a tradie's canopy with solid lift up side doors that hinge fairly high for good access. Saw it at last months 4wd show in adelaide. You might need to phone them to get details.
AnswerID: 498088
Follow Up By: Harry B2 - Saturday, Nov 17, 2012 at 20:53
Hi Phil G Sorry forgot to say that I have a Mazda dual cab with a tub.
Cheers HarryB2
FollowupID: 774673
Follow Up By: Member - Phil G (SA) - Sunday, Nov 18, 2012 at 08:02
Gday Harry,
Yep it was for a dual cab with a tub.
Go to their websideHERE and click on the 3rd brochure (called worksmart canopy)
FollowupID: 774685
Reply By: Member - bill f (QLD) - Wednesday, Nov 07, 2012 at 18:47
REcently fitted a Chieftain Canopy to my tray back. Went for the basic tradesman canopy with solid sides. They can make them for most utes in any style. If wanting aluminium M2O in Melbourne seem to have a good range. Might have gone for one except too far away to freight here. Bill
AnswerID: 498096
Follow Up By: Harry B2 - Saturday, Nov 17, 2012 at 20:54
Hi bill f, Sorry did not make it clear that I have a dual cab with a tub.
Cheers Harry B2
FollowupID: 774675
Reply By: Scotty - Wednesday, Nov 07, 2012 at 21:58
Harry, I was looking for one also carryboy was one that I looked at which had solid side windows and are internal lined and Had a quality finish, salesman was not very clued up but it looked good and well made, ended up ordering an egr as they have a 150kg load rating with the roof rack kit which I need for my boat loader.
AnswerID: 498102
Follow Up By: Harry B2 - Saturday, Nov 17, 2012 at 20:56
Thanks Scotty, will check them out.
Cheers Harry B2
FollowupID: 774676
Follow Up By: Scotty - Sunday, Nov 18, 2012 at 20:43
Bit concerned myself as I have ordered a ERG canopy with the 150kg roof rack kit as I have a WA boatloader which weighs 35kg and then a tinnie which weighs about 70kg so i hope that the tub does NOT split. I travel from nsw to Daly River every april 10,000 klms round trip at about 110klms per hr. Bought the BT50 so i could throw the gennie and all the other gear in the tub as i used to have a prado grande which had no problems.
regards
Scotty
FollowupID: 774729
Reply By: John M54 - Friday, Nov 09, 2012 at 19:55
Hi Harry B2, As an owner of a current model BT50 with a split tub, can i warn you to be careful. I fitted a canopy & racks & mesh cage, threw some things in & 3 weeks later had 4 splits in the tub. The total weight of the items on top of the canopy was 34kg. Mazda are refusing to fix the problem saying fitting these items caused the fault. I know of a ranger that was only carrying a swag up top & it also split the tub. The tubs are clearly not capable of carrying much weight on top. ARB have made a strengthening frame to compensate for this problem. [ hopefully it will do the job!] Other manufacturers may have also. Older models nor other manufacturers don't seem to have that problem - why is that? Do your research! Good luck John
AnswerID: 498239
Follow Up By: Harry B2 - Wednesday, Nov 14, 2012 at 21:45
Hi John, Is it the canopy that split or the car tub. I have a dual cab with a tub. What brand of canopy did you fit and what they say caused the splitting.
Thanks HarryB2
FollowupID: 774512
Follow Up By: John M54 - Thursday, Nov 15, 2012 at 20:21
Hi HarryB2, It was actually the car tub that split. [ In 4 places!]The supposedly weaker fiberglass of the ARB canopy is in perfect condition! ARB now make a strengthening frame to bolster the weakness of the tub. [ It bolts down the side of the tub to take the weight off the top of the tub. Strangely the canopy was originally mounted the same way as the earlier BT50s [& all the other car brands] & on these cars there have not been this problem. It is clear in my mind that this is only a problem for the current model BT 50 & ranger. They are the only cars that have had to be fitted with a strengthening frame!?
FollowupID: 774581
Follow Up By: Harry B2 - Friday, Nov 16, 2012 at 13:23
Thanks John M54
I actually bought a Caddy Canopy, but found that it was still too close to the body of the car and did not fit properly - squeezed at one end. They just refunded my dough. Seems they have not remedied their old problem yet. Guess I will have to go with the strengthening frame too, which I really wanted to avoid. I will have a small tinnie on top of the car/canopy which will weigh a bit. Does Insurance cover your split tub?
FollowupID: 774616
Reply By: Burnt Damper - Friday, Nov 09, 2012 at 21:23
Harry,
3XM in Brisbane made a fiberglass one which are great, they also can supply you with a tray and canopy matched together. I think they have a very high carrying capacity as well.
I have the present model BT 50 and got a custom made aluminum canopy made at a place called Tong Box 0732569633 (Brisbane ) . It cost me $4000.00 and I have travelled 23,000 km with it and haven't had a problem. For about 16,000 km I have had my 3.5 mt tinny on the roof plus 50lt of fuel and a spare tyre. I am presently sitting in Cooktown but have been traveling and working through most of the cape for the last 5 months and haven't had any problems with the canopy. Hope this helps . Cheers
AnswerID: 498245
Follow Up By: John M54 - Saturday, Nov 10, 2012 at 15:57
Hi Burnt Damper, Can you tell me how your alloy canopy mounts to the tub? Does it have supports to the floor or tub sides or is it simply mounted on top of the tub" Are you carrying anything on top of the canopy? Thanks for any info. John54 [ Also has anyone else out there fitted a genuine Mazda canopy & how is that fitted? Cheers John]
FollowupID: 774252
Follow Up By: Burnt Damper - Saturday, Nov 10, 2012 at 21:23
I am sorry mate my canopy is mounted on a tray back. I didn't want a tub because I thought it would limit me to much for what I wanted to do. But in saying that Tong box may be able to help you as well. As mentioned earlier I have a boat, fuel and a spare tyre on top of mine about 150 kg and all is good.
FollowupID: 774267
Follow Up By: John M54 - Monday, Nov 12, 2012 at 17:18
I obviously should have researched this matter further before i made a decision but i see so many utes on the road with set ups similar to mine that do work- i guess i was complacent. I now wonder whether even the weight of a canopy might be too much for the BT50 tub if used off road!
If i stick with the tub [& the car!] i will definitely get the tub strengthening frame kit ARB [& others?] are offering. Thanks for your help. John
FollowupID: 774379
Follow Up By: Scotty - Saturday, Nov 17, 2012 at 21:54
The strengthening kit does NOT strengthen the tub it takes the weight of the roof racks and spread (distributes) it into the tub. The tub should take the load of 150kgs and more, the canopy or racks would fail well before the tub.
I would question how the tub split, was it at the welds or where it was attached to the frame (chassis) it is no good speaking to car sales people as they really just open their mouths and let anything that comes to mind fall out, very few car salesmen are retired engineers.
You need to talk to a certified engineer which will cost money and time but all vehicles pass a stringent test to get certification and this would be the line to take.
FollowupID: 774679
Follow Up By: John M54 - Sunday, Nov 18, 2012 at 20:08
Hi Scotty, Yep understand what you are saying.When i said strengthening i meant in terms of the tubs ability to carry the weight of canopy etc. So i believe you are right. Re the splits they all started from weld points at the top of the front of the tub. [ the very top & front most weld points] Nowhere else seems effected. I have gotten a quote from a panel beater to fix the problem . He quoted $ 2591.05 which does not include the cost of changing over the dual battery set up , the reverse camera, canopy etc & respraying new tub with protective plastic treatment. [ which was done to the old one] [ approx another $ 1600?] An auto engineer starts at $ 2000 [ just to begin] so is a very expensive option to be weighed up against the cost of fixing it. You can see why I'm taking it to court! At the moment I'm busy taking photos of Utes fitted out similarly to mine & also of Utes systems for carrying weight to use as evidence that the BT 50 does not live up to normal use expectations. A Ford ranger that went to the cape only had a swag up top & that was enough to split the tub. I would appreciate info from anyone else in the same situation. Cheers John
FollowupID: 774722
Follow Up By: Scotty - Sunday, Nov 18, 2012 at 20:38
You can purchase a new tub for $500, look on the web as a few have purchased the BT50 with a tub so they can get the auto and have ripped them off to build a total canopy. I have seen at least 5 for sale ranging from $500 to $750.
Good Luck...
FollowupID: 774727
