Cruiser Cab Chassis Sagging Springs
Submitted: Friday, Nov 09, 2012 at 15:29
ThreadID: 98936 Views:6665 Replies:11 FollowUps:4
Brand spankers with 1100 on the clock. Trade Bodies canopy @ 300kg + perhaps 100-150kg in odds and ends.
The passenger side has dropped 30mm relative to driver's side (front and rear). Rear pass spring is flat.
Goes in to the stealer on Monday for the complimentary 1 month look over and I mentioned the issue when booking in.
Anyone else encountered this much sag this early.
Currently it looks like a dog with worms....
Reply By: Ozhumvee - Friday, Nov 09, 2012 at 15:48
Cruisers have suffered from sagging springs since they first arrived back in the 60's, there has to be a reason for so many aftermarket suppliers in Oz.
Best of luck with the stealer, I fought long and hard the first time, then they replaced them and six months later they were as bad as the original set, never bothered after that just factored replacement suspension into the price.
AnswerID: 498212
Follow Up By: member - mazcan - Thursday, Nov 15, 2012 at 12:11
hi peter
yes i can relate to the same issue on my 1982 land cruiser wagon the rear springs went flat in the first 10,000km's they were ok until i did a short trip with my 18ft viscount caravan lightly loaded and the springs after that were history so has anything changed
the trayback lc ute where i worked had flat sagging springs 6 yrs ago as well
you pay a premium for a toyota and still to this day have to almost immediately upgrade the suspension
on top of the expensive initial purchase price
imho thats not good enough and do the japs care
well no not while us aussie fools keep buying them !
im convinced and always have been that toyota use some very cheap steel to make springs
FollowupID: 774543
Follow Up By: Ozhumvee - Tuesday, Nov 20, 2012 at 11:41
I don't think it is cheap steel as such but that they don't make their springs as hard as Australian spring steel.
You will rarely break a standard toyota leaf but it is easily done on local springs due to the higher hardness.
FollowupID: 774841
Reply By: splits - Friday, Nov 09, 2012 at 16:26
Rosco
I remember replacing a lot of sagged Hilux front springs under warranty at work back in the mid 1980s. There were no problems with the Cruiser ute, troopy or the 60 series.
See what the dealer says. If you are not happy then insist they arrange for a Toyota technical rep to meet you at the dealers. Don't fit non genuine springs at this stage. If they cause any problems then you are on your own. Toyota will not be interested.
AnswerID: 498215
Reply By: The Bantam - Friday, Nov 09, 2012 at 17:02
First question......how does it sit completely unloaded
Have you weighed it.
front rear split.
If there is room and a co operative weight bridge operator you may be able to get the rear wheels on the bridge one at a time by backing on at an angle......some bridges you just cant
No point going to the dealer without all the information and a solid case
Don't get all twisted about the springs being flat either...look and see how much travel there is remaining before it sits on its bump stops.
My hilux is definitely not sagged and the springs sit flat the way it is loaded.
All the toyota utes as factory sit down in the ass when fully loaded.
AnswerID: 498220
Reply By: wjh41 - Friday, Nov 09, 2012 at 17:50
Dont let it bother you too much Rosco leaf spring Patrols are no better,thats why most of us upgrade the suspension. good luck Wally
AnswerID: 498225
Reply By: Notso - Friday, Nov 09, 2012 at 17:55
One of our vanners has had the same issue, ended up putting firestone airbags on it.
AnswerID: 498226
Reply By: Member -Pinko (NSW) - Friday, Nov 09, 2012 at 18:35
I have a 2007 70 series with a canopy and yes sagged rear springs.
If you are going to replace the rear have a look at Sax Suspension before you decide on what to buy.
AnswerID: 498230
Reply By: olcoolone - Friday, Nov 09, 2012 at 19:20
Springs are a funny thing and just because they sag or even invert with weight doesn't mean they are stuffed...... the hard thing is in the case of a Landcruiser 70 series is being able to make it carry the weight but most importantly passenger comfort and driveability.
If it had coil springs in the rear you could get the best of both worlds by using progressive rate springs.
The springs in OEM applications are designed to carry the said weight but not constantly, if they were made to carry a constant weight you would have 95% of the people with them fitting softer springs illegally derating it's carry capacity making it defectable.
As said above that is why there are so many aftermarket spring makers.
If you want a bit more capacity you could pull the spring packs apart and remove the anti friction plates..... this may give you another 20% capacity but the down side is it makes them a bit louder.
AnswerID: 498237
Follow Up By: Member - Markthemilko - Saturday, Nov 10, 2012 at 00:31
I fitted a parabolic leaf set to the rear of my 2007 VDJ79 ute. Only 3 leaves each side = less weight and a much more 'sedate' ride now!!. But the front bushes supplied were totally trashed after 14,000kms and one bolt broke across the grease hole, on the Anne Beadell Hwy!! Fortunately I had a suitable bolt that got us home! The Perth agent replaced the bolt & bushes at no cost, and advised me that genuine Toyota bushes are the best and that's what I fitted all round, not long after.
Happy 4WDriving
Mark
VKS 737 mobile 0401
FollowupID: 774216
Reply By: Dennis Ellery - Saturday, Nov 10, 2012 at 21:47
Have you ever put it over a weighbridge?
I have and it’s a bit of a surprise.
Toyoto use the term Landcruiser on a lot of different models – 200 series, 70 series, even the Prado is a Landcruiser - I assume your Landcruiser is a 70 series.
I have a Troopy – 1 tonne load capacity.
Carrying 2 humans (170kg) 2 Tanks of fuel (180kg) 2 Engels full of food and drinks (100kg) 2 spare tyres (100kg) Caravan on towbar (200kg) Bull bar (50kg) add a bit of 4WD gear, jacks, straps, compressor, etc and you are getting up to full load.
And that’s without adding grog and a few other things.
AnswerID: 498309
Follow Up By: Member - Rosco from way back - Saturday, Nov 10, 2012 at 23:31
All true Dennis
But I only had a relatively light load up. Hence my surprise with the springs.
FollowupID: 774285
Reply By: get outmore - Saturday, Nov 10, 2012 at 23:19
since they went the longer springs with the 79, they lost most of there load carrying ability with standard springs
they really benifit from new springs it will add alot of hight
AnswerID: 498314
Reply By: Member - Rosco from way back - Monday, Nov 12, 2012 at 16:55
Well ............
Back from the stealer ... at least they were honest and agreed the springs are way too soft these days. They wacked it on a weighbridge and returned 1291 kg to the front axle and 1526 to the rear with bugger all difference side to side. At 2817 kg (both tanks almost full) that's way under the GVM to which they agreed. They could only suggest airbag helpers and made the observation that in their opinion after market springs/shocks would be too harsh.
Your thoughts gents ??
AnswerID: 498396
Reply By: KevKim37 - Monday, Nov 12, 2012 at 23:52
Purchased our 79 series Turbo 1HDTFE new in 2004 and with 3.76tonne and towing 3.5tonne Boroma started of with a set of PolyAir Bags inflated to 90psi with Std springs until 2007. Then upgraded legally to 3.76t (new H/Duty springs/shocks all round) and now only need to run approx 30-60psi in air bags and unloaded ute still rides good.
I am still using all of the original Rear Spring bushes and they show little or no signs of wear or bad deformation at 90,000kms with this load which is on at least 70% of the kilometres driven as we are on the road full time. That has included a trip up Cape York and a couple of trips camping west of Cairns of course without the van.
Cheers Kev.
AnswerID: 498418
