Tray for dual cab Hilux 08 model.
Submitted: Sunday, Nov 11, 2012 at 17:19
ThreadID: 98963 Views:3471 Replies:2 FollowUps:1
What is the maximum size tray you can put on a Hilux?
Can you carry the Trayon with the tapered back or do you have to have the cut down version with the bit protruding over the roof?
Reply By: Member - Wamuranman - Sunday, Nov 11, 2012 at 18:15
Hi Twinkles,
You will need to confirm with your State Transport Department but I recall the regulation is 60% rear overhang ...i.e. 60% of the distance between two axles. Then take 60% of that measurement from rear axle to end of tray.
AnswerID: 498354
Reply By: whackywombat - Sunday, Nov 11, 2012 at 19:40
I believe the tray length for a dual cab would be 1.8 mt. You need to purchase the dual cab trayon model.
AnswerID: 498359
Follow Up By: AlbyNSW - Sunday, Nov 11, 2012 at 21:07
Agree 1800 is standard, even if you could legally make the tray longer it is a lot of weight out behind the rear axle so not a great idea regardless
FollowupID: 774340
