tow hitch
Submitted: Tuesday, Nov 13, 2012 at 12:52
Member - Broodie H3
Good morning fellow travellers, I was just wondering if anyone has a Mchitch on their caravans, to see if it worth the trouble of changing my current tow ball hayman Reece hitch to this new one. At the moment I don't have an issue with the system that is on our caravan apart from the occasional loosening of the tow ball which I check on a daily basis as part of our routine for getting under way each morning.the current system is easy enough to couple up I was just wondering how hard is it to hook up to this new uniglide system made by McHitch and if any one has any issues with it. Any comments would be appreciated.
regards
Broodie H3
Reply By: Member - dmaughan - Tuesday, Nov 13, 2012 at 16:21
I have a McHitch installed on my 17' Jayco and am very happy with it. I find it very easy to hookup even on rough ground. Occasionally I have to give it a bit of a tug to get it to
seat all the way down but I don't find this too much effort.
I have a friend with the Highland on his Van and he is also very happy with that so it is really only a personal preference thing. The only real difference is that with the McHitch you get a solid connection between the hitch and the vehicle, I personally prefer this setup.
I have also heard that you might have difficulty with a McHitch if you use a WDH as the pivot point is further back to where the bars are fixed - hearsay only, I don't know if it really makes that much difference.
I you are happy with the Highland I probably would not bother with the McHitch it is an expensive outlay for not much gain, unless like me you really like the idea of a solid connection to the hitch.
Dean
498436
Follow Up By: AlanTH - Wednesday, Nov 14, 2012 at 10:00
We have a McHitch on our small van and find it very easy to align on hook up and it's so solid.
Used to have a D035 but found that to be a fiddly pain in the butt especially if on rough ground.
Early days with the McH but certainly good so far but we don't use any sway bars or levelling devices.
AlanH.
774460
Reply By: Member - firmy (NSW) - Tuesday, Nov 13, 2012 at 19:41
Hi Broodie I have a 6 ton McHitch very happy with it .Tow a 22 foot offroad Fulcher dont use WDH go anywhere GU will go, no rattles on rough roads very easy to use.cheers Firmy
498449
Reply By: Bobjl - Tuesday, Nov 13, 2012 at 22:07
I have used a Big Yella Fella 6 tonne McHitch to pull 23 footer 3.5 tonne Van >10,000k's,
I purchased McHitch for the security and safety of the 6 tonne rating and the apparent benefits of the big strong post and attachment design with two securing features. I found it reasonable to hook up although accurate alignment was necessary to ensure the side locating lugs may be positioned as required. It was reasonable to unhook but occasionally some tension occurred [dependent on van position].
Unfortunately I was forced to replace the McHitch with a different "off road hitch" due to issues that arose when using my particular WDH. Those issues were from my experience exacerbated by the rear set articulation point which is a design feature of McHitch. I had no issue with the quality of the physical manufacturing and felt comfortable that McHitch was up to handling big rigs.
The issue that arises when using my particular WDH may be minimised dependent upon the position of the tow coupling relative to the WDH hangers and the overall chain length achieved. If less than 7 or 8 links in play and coupling not low set on the A frame, then when turning the vehicle, the rear set articulation point means the WDH bars will move for/aft and also further sideways and create potential for significant forces which may cause damage [as I experienced].
I understand other McHitch owners are using different brand WDH and they have not experienced the issues I have.
Now that I have reverted to a set up with the usual articulation point [at the tow ball] with the new off road type coupling [4.5 tonne] there are no issues and it allows me to make tight turns - small roundabouts and even a turn in a narrow road with WDH in place.
I also used Hyland 3.5 Tonne for several years and many thousand k's successfully and only replaced it to achieve a higher and more secure tow capability rating [> 3.5 tonne].
I hope this helps
498454
Reply By: Member - Broodie H3 - Wednesday, Nov 14, 2012 at 12:18
Thank you everyone for the input , I think I'll wait and see what is on our new van when we get it and look into it further at that time. Once agian thank you.
Broodie H3
498494
