Painting A Frame & Chassis on Caravan
Submitted: Thursday, Nov 15, 2012 at 11:59
Tony N2
Hi my caravan is 8 years old and I thought it was time to paint the chassis it is hot dipped duragal what would be the be product to do this with it will have to be brushed and spray can as I can not spray paint
Thanks Tony
Reply By: The Bantam - Thursday, Nov 15, 2012 at 12:19
OK...to start with is it hot dipped or is it Duaragal.
If it is Duragal...a steel product plated at the time it was milled.....Galmet Duragal is ya product...I've had a very good trot with it...it is a thinners bassed product intended for spraying, but with a quck hand it can be brushed....this is a product specificaly intended for touching and recoating factory plated steel.
If it is hot dipped, some would say it does not require painting......BUT..paint beats plate any day.....good paint over good plate is about as good as it gets.
You will need and etch prime.....the only easily available turps bassed etch prime I know is the Killrust product.....it is the turps bassed cousin of Wattyl SuperEtch whic I have had a good trot with and is
well respected........both single pack epoxy, etch primer, undercoat....
then select your top coat......Kilrust Enamel, is respectable if you want to brush and is a single pack epoxy enamel.
The etch prime followed by enamel will be fine on duragal too.
remember you will need to scrub and solvent wipe first....for this use GP thinner.
498569
Reply By: Member - Rosco from way back - Thursday, Nov 15, 2012 at 15:16
Alternatively you could go with a zinc rich "cold galv" type paint which can be brushed on. You could then apply a top coat over if required.
I respectively beg to differ re the need for etch priming as this is usually only needed for new galvanising and after 8 years this should not be necessary.
498574
Follow Up By: Member - Rosco from way back - Thursday, Nov 15, 2012 at 15:18
Oops ... make that "respectfully"
A pity threre's no edit button.
774567
Reply By: kev.h - Thursday, Nov 15, 2012 at 18:30
Hi Tony
Through work we use a product called rust bullet - Google it - its the toughest product I've come across its brushable and has a finish like hot dip, use the automotive grade the industrial grade is hard to get a good finish
We use it in the sewerage industry and you cant get a more aggressive /corrosive environment than that
A company at Nambour is the importer "McBerns" and no I have no other association other than use their product
If you want I could send you a small sample painted on some steel so you can see what its like
Cheers Kev
498583
Reply By: Dennis Ellery - Thursday, Nov 15, 2012 at 23:27
If it’s hot dipped galvanised as opposed to duragalv you are lucky – it’s the best you can get for a caravan chassis.
Any corrosion proofing that is effective has to be done at the manufacturing stage of motor vehicles, caravans etc. Anything done after is only be good for a cosmetic effect.
498600
Reply By: Member - bbuzz (NSW) - Saturday, Nov 17, 2012 at 09:59
The only drawback to this plan, is you have to do it lying on your back under the van.
Long sleeved shirt, long duds, gloves or big bottle of turps to get it off every square inch of your skin (and face!)
Great job but it needs to be done from time to time.
LOL (lots of luck)
Bill
498653
