RE Fridge/freezer problem
Submitted: Saturday, Nov 17, 2012 at 21:37
Member - Terry E (NSW)
I have just purchased a fridge/freezer but when I plug it into the cigareete lighter I get a red error light and it doesn`t appear to work.There is an amber light that comes on when first started and you hold it for a few seconds and the compressor kicks in and a green light shows but then this error light comes on. It works perfect off the mains. The company I bought it from says it should work off the lighter. Can anyone offer some advice. Also when checking on it as we were travelling I noted that it switched off ( ie. no amber light ) when the car was turned off. I guess this is normal as the car has to be started for it to work, but if there is something else I can do to overcome this I would appreciate any comment. As you can tell I`m not a techspert.
Reply By: Member - Toyocrusa (NSW) - Saturday, Nov 17, 2012 at 21:49
Hi. you don't say what brand or size of fridge it is but it is quite possible that the wiring to your cigarette socket is not heavy enough. Does the fridge work with the engine running and plugged in to the lighter socket, if it does then the wiring definately needs to be upgraded. Bob
498677
Reply By: Dennis Ellery - Saturday, Nov 17, 2012 at 21:59
Is it a Waeco?
498678
Reply By: member - mazcan - Saturday, Nov 17, 2012 at 23:32
hi you need to set up a dedicated 20 amp wire with an inline fuse to run your fridge off in particular if it is a waeco directly from your battery
cig liter socket wiring on almost all vehicles is far to small to operate a fridge off it
the signals your getting is indicating the fridge is not geting enough current to run
many others have had the very same problem
498683
Reply By: Member - Boobook - Sunday, Nov 18, 2012 at 06:21
There are a gazillion threads on this and other forums on this. As per what a few others said, it it the tiny wiring in your vehicle which is underrated to save money. You need to get it upgraded and all will be
498685
Reply By: Member - Terry E (NSW) - Sunday, Nov 18, 2012 at 09:13
Thank you to all who have replied, I think you have solved my problem and I will check out the wiring. The fridge is a Ozrover.
498691
Reply By: ABR - SIDEWINDER - Sunday, Nov 18, 2012 at 09:25
Hi Terry
As mentioned you should run a dedicated cable. We recommend 6mm2 cable as shown below.
Derek from ABR
498693
Reply By: Member - Terry E (NSW) - Monday, Nov 19, 2012 at 08:25
Thanks for the diagram, Sidewinder unfortunately I`m in NSW and you are in Qld otherwise I would get you to do it. Much appreciated for all the advise from all who took the time to add their comments.
498754
Reply By: Nomadic Navara - Monday, Nov 19, 2012 at 13:01
Terry, cigarette lighter plugs are the last thing I would use for anything I would require to be reliable. The sockets in cars were not designed to make a good connection, in fact the reverse. The cigarette lighter was pushed up onto the contact, the poor connection in its socket was part of the heating process. If the existing socket is slightly dirty this could be part of your problem.
Your Waeco plug had a red/
orange sleeve that can be removed to convert the plug into a Merit plug. These make better contact in the socket. The positive connector slides into the socket connector, this provides a self cleaning action each time you insert or remove the plug. The slide in connection also has more surface connection and more tension on the contact. Contrast this with cigarette lighter plug that just pushed up with socket connector, no self clean and minimal contact.
I suggest you get a Merit socket (or a few) postal order from Derek or somewhere like Jaycar. This will make a more reliable connection for your fridge.
498773
Reply By: Member - Terry E (NSW) - Tuesday, Nov 20, 2012 at 16:51
Thank you Peter I will check out all options.
498886
