Hzj 75 waterpump
Submitted: Sunday, Nov 18, 2012 at 16:01
Madsnake
G'day all.
Changing my
water pump on the troopy (94 hzj 75) just wondering anything else to change or look for while I'm at it? Obviously timing belt, fan belts etc
Reply By: pop2jocem - Sunday, Nov 18, 2012 at 22:45
Maybe remove and test the thermostat and get the radiator flushed/serviced if you have it out. May also pay to fit new hoses if you haven't changed them in a while.
That should have the whole cooling system ship shape for the coming summer months.
apaop
498740
Reply By: taswegian - Monday, Nov 19, 2012 at 08:30
G'day,
Replace timing belt tensioner bearing & cam seal, some belt kits include these. Use a wire loop to remove tensioner spring to replace you can use a grooved screw driver be prepared to have your sense of humour tested. It makes things so much easier to remove the radiator and surround the ideal time to clean & flush.
Cheers, Taswegian.
498755
Reply By: Madsnake - Wednesday, Nov 21, 2012 at 17:13
Yea beauty. Cheers for that. Hopefully everything goes to plan.
498935
