Comment: Gibb River Road
Submitted: Tuesday, Nov 20, 2012 at 09:26
Hannah B1
My husband and I are thinking of travelling from
Darwin to
Broome in June/July 2013 on the
gibb river road. Can anyone recommend to tow a boat along this road and also we are travelling in a Toyota pardo with a rooftop tent with an alloy roof rack. We have heard different reports about steel or alloy, were alloy can rattle off does anyone recommend if the alloy will do the job or should we buy a steel roof rack. Thanks Hannah
Reply By: AlanTH - Tuesday, Nov 20, 2012 at 09:58
Hi Hannah.
The Gibb is really not that bad. We've towed a camper and small van on it with no problems. If you ensure all the rack holding bolts are tight and things are
well secured you'll be OK. Steel is supposed to flex better than ally but ours has always held up OK.
If travelling to
Drysdale River or
Kalumburu the road conditions can be much worse but as always moderate your speed and lower tyre pressures.
Take the usual tyre plugging gear and other emergency stuff (take Drysdale's phone number as
well as they'll help in emergencies but will charge for their time which is fair enough) and enjoy yourselves.
Cheers.
AlanH.
498865
Reply By: MEMBER - Darian, SA - Tuesday, Nov 20, 2012 at 10:53
If the boat trailer is robust, has tough tyres and you take it ''quite easy'' where required (plus adjust tyre pressures to suit terrain), there's a very good chance you will have a happy run on the Gibb. Just to add to the above - from the Gibb, the
Kalumburu road up as far as
Drysdale River Station is often as smooth as a baby's bum.. it's usually north of there that things get challenging for suspensions and other hardware. Also.....check the Drysdale Station website (Roads and Travel Tips), re their latest policies on assitance for roadside breakdowns etc..
498868
Follow Up By: Member Andys Adventures - Tuesday, Nov 20, 2012 at 20:05
It would only be smooth as a baby's bum straight after the grader. Was there in June this year and it was as rough as a 90 year old bum
774897
Reply By: Kris and Kev - Tuesday, Nov 20, 2012 at 13:07
We did the Gibb last year in July/August from
Broome and the Gibb was in very good condition until the El Questo turn off. I believe that they either have or are sealing that section now, which is a bit sad.
It also depends on how many
places you want to see on the way. The Gibb is only about 640 km long, we did 3,000 on it in 4 weeks, visiting all of the gorges etc.
The road to Drysdale was pretty corrugated when we did it, but driving to the conditions it was still OK. The road from Drysdale to
Mitchell Falls was pretty bad and the road to
Kalumburu was real bad. But again, driving to the conditions was the secret.
We have a alloy roof rack and the only problem I found when we got home was that some of the screws holding the rack to the roof had came loose. Probably because we had been on heaps of corrugations, so it does pay just to check them as you go.
Kevin
498876
Follow Up By: whisky_mac - Tuesday, Nov 20, 2012 at 15:46
Yeah, El Questo to the end is rough, big basalt boulders. At one stage I stopped to check if a guy with a holed radiator was OK. He was but it took me for ever to get back up to a comfortable speed because the corrugations were so bad. I have been told that that bit gets a lot more traffic as many come out to
El Questro and then return.
774858
Reply By: Peter_n_Margaret - Tuesday, Nov 20, 2012 at 18:24
We have towed 2 different boats to
Kalumburu and back without serious issue (one from
Adelaide via the Anne Beadell and the other from
Brisbane via the Plenty and
Gary Junction Highways).
That said, I have seen lots of boat trailers suffering damage at
Kalumburu. Mostly because they were obviously not up to the task.
Brocken boat supports, mudguards falling off, spare
wheels falling off etc, etc.
I would not go back to
Kalumburu without a boat.
OKA196 Motorhome
498891
Follow Up By: Kris and Kev - Tuesday, Nov 20, 2012 at 20:11
Oh
yea, I would totally agree with that. We stayed at
McGowans Island and there were a lot of fellow campers there with boats and they always came back with heaps. The following was our
camp spot and then what I remember of our BBQ, plus fish of cause!
774898
Reply By: Gossy - Wednesday, Nov 21, 2012 at 18:24
we just got back about 2 months ago. 2 Prado's and our GQ Patrol. Roads were very corrugated in some
places with tyre shredding rocks all over the road.
My personal opinion is:
1. Prado not a problem
2. rooftop tent on alloy rack not a problem
3. boat trailer. No. wheel bearings, extra tyres to worry about and carry spares for. Not to mention the constant shaking of your boat that simply isn't designed for that. I'd expect damage on the boat so could be expensive trip if this happens
498940
Reply By: Member - Bucky - Thursday, Nov 22, 2012 at 04:39
Travelling the GRR is not a problem, if you are perpared to just plod along, accordiing to the road conditions.
That is the clue, according to the conditions.
We towed out Trak Shak up the GRR, not long after the graders had been thru most of it, so 70 - 80 km/hr was the order of the day, and approx 25 psi in the tyres.
Had a dream run.
Chuck in no graders for a while, and bad corrugations, and it can turn into a nightmare real quick.
Remember
You are on holidays, and towing, so just slow down and enjoy it
CHeers
Bucky
498964
