Mapping Issues with Oziexplorer - Printing
Submitted: Friday, Nov 30, 2012 at 11:59
Hello,
I am in a bit of a pickle with printing.
I need to print the full map to give to our reps but for some reason it is not letting me.
i have tried everything messing with the size of pages, the amount, the scale.
but all it seems to do is print a 1mm by 1mm map.
so the only other option i have is to copy and paste the into a word doc.
Please if you have anything please send it through.
Reply By: SCUBADOO - Friday, Nov 30, 2012 at 12:46
I can't begin to guess where you problem lies.
Just tested here and the options work perfectly. "Map - Fit to page(s)" does just that.
Presumably under "Setup" you have checked that the printer and page size details are correct?
499511
Follow Up By: 444 - Friday, Nov 30, 2012 at 12:57
Thank you so much for the help.
I checked the printing set up and changed it to A4 (before it was pdf) and nothing changed.
775519
Reply By: Member - Boobook - Friday, Nov 30, 2012 at 13:32
Do you have the paid version or the free trial version?
499516
Follow Up By: 444 - Friday, Nov 30, 2012 at 13:47
I am pretty sure it is the full version. it is on CD and it has added features of trail versions of Ozi explorer3D and CE. we also paid for it.
775521
Reply By: Member - Michael P (QLD) - Friday, Nov 30, 2012 at 14:11
HI,
When you are on the print page, select " selected _to fit page" then to the left of that is a map icon, click on that then you will have an outline tool to highlight the area of map that you want to print. Preview before you print.
Most of the selections are fairly easy to follow eg landscape/portrait.
Sorry if not explained clearly enough.
Mike.
499518
Follow Up By: 444 - Friday, Nov 30, 2012 at 15:02
Hello Mike,
I dont have that option in my print page? all i have is:
windows- fit to page and window - to scale?
Is yours a updated version?
Bronagh
775525
Follow Up By: SCUBADOO - Friday, Nov 30, 2012 at 15:14
If you don't see this it is either an old version or unregistered.
775526
Follow Up By: 444 - Friday, Nov 30, 2012 at 16:18
Hmmmmm the plot thickens.
I might need to see if i can get an update.
and how can you register?
775529
Follow Up By: SCUBADOO - Friday, Nov 30, 2012 at 16:42
Help > Registration Notice - will let you know if it is registered.
Help > Enter Registration Code - fairly obvious. (-:
775532
Follow Up By: 444 - Friday, Nov 30, 2012 at 18:01
Thank you :)
775537
