Gas leak detector
Submitted: Saturday, Dec 01, 2012 at 10:36
ThreadID: 99280 Views:2463 Replies:4 FollowUps:8
Going to be living in our new van soon and would like info on the gas leak detector units. Where do you buy them from and how much?
Richard
Reply By: taswegian - Saturday, Dec 01, 2012 at 14:04
G'day,
You can get a good 12v one from $60 onwards. Try Ebay, ship chanderies or caravan aftermarket place.
AnswerID: 499584
Reply By: Members Pa & Ma. - Saturday, Dec 01, 2012 at 20:05
Hi Richard,
I know of a very old type which was made at Dong Yang Transformer Ind Co Ltd.
Model DYG. 1998 approx. There is an after market Store called Camex. I think. I have no association with either. A friend has the van.
Take care, safe travels.
Bye for now. Ma.
AnswerID: 499608
Follow Up By: 410 - Sunday, Dec 02, 2012 at 08:02
Thankyou for the info.
FollowupID: 775631
Follow Up By: Members Pa & Ma. - Sunday, Dec 02, 2012 at 11:58
Back again Richard,
I just had another thought....& have done some research.
If you are living in the van on not both the Gas Detector & a carbon Monoxide Detector are advisable from what I've been told just type either into Google .I've found some which are combined. Don't know how good they are.
Take care, Safe travels Ma.
FollowupID: 775641
Reply By: Stan2.8D - Sunday, Dec 02, 2012 at 13:53
I would definitely get the detector (Bunnings etc should have the battery operated dual gas/carbon monoxide monitors). But another thing to do is to turn off the gas after EVERY use and leave burner on to drain gas in hose then be sure to turn off the burner as well!. This also helps the longevity of the regulator apparently.
If you have something like a gas fridge then obviously you cant do this, in which case a detector is even more important especially if the pilot goes out as there was a fairly recent explosion due to exactly this happening.
AnswerID: 499665
Reply By: Member - bungarra (WA) - Sunday, Dec 02, 2012 at 14:16
http://www.ebay.com.au/itm/271088749918?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I have ordered one of these with the intention of hard wiring it into the 12v system inside the 'van...the draw is minimal and when not living in the 'van the main switch turns all 12v system off anyway......conversly when using the 'van the 12v supply is allways on
Reading the specs whilst it plugs into 240v outlet it is obviously reduced to a a DC voltage within 9-16 v so wont be an issue...that way always on guard and no battery change to worry about
VKS 1341
AnswerID: 499667
Follow Up By: 410 - Monday, Dec 03, 2012 at 07:18
Hi All
Thankyou all again for the info, as we know gas is a silent killer.
Richard
FollowupID: 775668
Follow Up By: GEMAC Solar and Power - Monday, Dec 03, 2012 at 09:33
Richard
All vans are requied by law to have some form of venting at ground level.
It is amazing how many are blocked off during travels and at night to "stop the draft" or to "keep out the cold"
If these vents usually in the door are kept clear and a small vent or breathing skylight is used in the roof, gas and co2 or carbon monoxide buildup will not occur. All these gases are heavier than air and will 'fall' out the door vent
Geeoff
FollowupID: 775677
Follow Up By: GEMAC Solar and Power - Monday, Dec 03, 2012 at 09:35
Meant to add that prevention is way way better than having the gas buildup then have the alarm go off in the middle of the night.
I figure a small draft or a little cool fresh air is way better than being gassed or be in the middle of a gas explosion when you turn on the light etc
FollowupID: 775678
Follow Up By: 410 - Monday, Dec 03, 2012 at 17:36
Hi Geoff
Thankyou for the info, i am aware of this vent but having a van with 3 bunks and the bottom one close to the floor, you can never be to carefull with safety when it comes to your children.
Richard
FollowupID: 775712
Follow Up By: Stan2.8D - Tuesday, Dec 04, 2012 at 09:44
Perhaps as the gases are heavier than air, perhaps put the detector near floor level?
FollowupID: 775751
Follow Up By: 410 - Tuesday, Dec 04, 2012 at 17:47
Hi Geoff
Good idea, i will do that. Thankyou.
FollowupID: 775777
