Caravan Airconditioning "the truth about their performance"
Submitted: Wednesday, Dec 05, 2012 at 22:43
Jeff P
Hi I would like the honest truth about the performance of your caravan airconditioner like vs a split system in your home, Iam having a 24ft van built and would like to no the HONEST truth about the performance and noise of the Ibis and the dometic equivalent I currently have 23ft Boroma 2007 model which is fitted with the dometic A/C and it is way to noisey it seems to cool ok but the noise! vs a split system drives me crazy even on low ,as I have replied to in a previous post its about time caravan manufacturers came up with a better solution to caravan airconditioning, the comment i got from the manufacturer was "thats what everybody uses,coming from poeple who claim to be the rolls royce of caravans
Jeff
Reply By: Notso - Wednesday, Dec 05, 2012 at 23:11
The Truth,
Noisy, Inefficient, expensive. But when it's hot, none of that matters. I even got used to the noise when working night shift and sleeping during the day when the temp was 47 degrees.
499880
Follow Up By: Jeff P - Wednesday, Dec 05, 2012 at 23:21
Thanks I threw my roof top a/c on my work caravan (old 24ft not insulated) and fitted a split system 3.25w result quite cold no more problems sleeping on night shift!! central Queensland 40 c plus
Jeff
775874
Follow Up By: Member - Rick P (NT) - Thursday, Dec 06, 2012 at 10:53
Yes all of the above and if it's really cold, 5-7c or colder it doesn't work as a heather as
well, sounds like a split system is the go.
Rick P
775890
Reply By: Member - wadams - Thursday, Dec 06, 2012 at 11:12
Hi Jeff,
We live permanently in our 25ft Jayco with two slideouts in northern SA.The van is parked in a shady area. I have an Ibis in roof aircon and this is what happens. I always run it on Auto as the book says and in the winter i.e. frosty nights it can be 0 deg C ouside and the temp will come up inside to about 10 deg c then freeze. Once it does an auto defrost it will then go up to about 19 or 20 but can't get it up to the set temp of 24 until there is sun on the roof.
In the summer, 40 deg I can only get the van to cool down to about 30 until the sun goes down and the ambient temp drops also.
Had a similar van in
Kununurra for 3 years and didn't have quite the same extreme temps up there and the aircon worked fine.
To me, the Ibis is OK except in extreme temps, hot or cold.
They are noisy and I know that others that I've spoken to who permanently live in their vans that for best results a split system is probably the way to go. Especially when buying the van new.
That's the HONEST truth as per your request.
Warren
499897
Follow Up By: Jeff P - Thursday, Dec 06, 2012 at 16:03
Thanks Warren I appreciate your reply
Jeff
775914
Reply By: Featherfoot - Thursday, Dec 06, 2012 at 18:38
Hi Jeff, we traveled around Australia for 15 months and had a 3.6 kw Panasonic household type split system air con mounted on the rear bumper of our 20 ft van, it was really quiet and very good at cooling as
well as heating. Never had any probs at all with it. Used it heaps. Traveled mostly on the black top. Other people we spoke to were amazed at how quiet it was,one guy who was next to us at a van
park was apologizing for the noise his his air con was making, his was a Heron split system that was located in the side of his van under a cupboard and yes it was very noisy, not that we would complain to him about it. So my opinion is go for the household type split system. You will just have to find somewhere inside for the head unit. We put ours in one of the overhead cupboards. Just removed the doors. I have seen an Aussie Wide van with a split system fitted by the factory, seemed to be
well done. The owner was pleased with it. I have no affiliation with Aussie Wide or Panasonic. Hope this helps.
Gary
499914
Reply By: Batt's - Friday, Dec 07, 2012 at 13:06
split systems are great in a van just make sure it has a min 4 speed fan which helps keep the fan noise down
499971
Reply By: Ian & Sue - Friday, Dec 07, 2012 at 16:57
We have a Coleman airconditioner on the roof of our Kedron. We have it sitting in full sun in
Karratha and during this past week when the outside temperature has been sitting around the 40 to 42C mark I have had the airconditioner running as a check that all is Ok before we head off for our summer vacation. Turning the aircon on around lunchtime when the thermometer is showing around 38 to 39 inside the van it can be bought down to a nice and "icy" 21C within an hour of running. I am happy I don't need to regas before departure.
Noise wise, yes you can hear it running but It doesn't bother us probably because we are used to having a constant airconditioner noise in the house. You cannot even hear it running when you are outside of the van.
Sue
499979
Follow Up By: Jeff P - Saturday, Dec 08, 2012 at 20:42
Thanks for the reply Sue and thanks to everybody that replied your feedback is welcomed, we will be in
Karratha for xmas hope its not too hot !
Jeff
776011
