satelite tv system
Submitted: Monday, Dec 10, 2012 at 22:01
bill
short question, for complex problem.
sat tv connection for caravan. connected to av on tv, then to sat dish via set box. dealer says set box to chann 1, tune to satelite signal will appear. co-ord sheets supplied for this area near melb.. north offset 20deg . elevation 45deg, polarization 30deg + this should pick up sat optus c 10. have sat finder set at reference 5 will advance to 8 with dish rotation. shoud be sat, but no signal. realise this info is useless unless someone has done the exercise looking for any help.. think system is phoenix purchased in qld
Reply By: Member - Rod N (QLD) - Monday, Dec 10, 2012 at 22:38
Is your sat system a UEC VAST decoder? If so follow the procedures on the Austech
Forum VAST tuning procedure The VAST system tuning/info channel is 8.
By the way the satellite you need for Australian TV channels is C1, which is on a heading of 7 degrees.
If it is the Aurora system I can't help. The Aurora system will close by the end of 2013 so VAST is the only real way to go now.
500151
Follow Up By: auzinomad - Tuesday, Dec 11, 2012 at 10:27
If you have a iPhone or Android phone you can get a few apps that will locate the Optus Satellites for you.
Google sat finder or dishpointer.
Main one at the moment is C1 later to be D2
The apps will give you all the co-ordinates and also give you a sighting of the sat as
I use Dishpointer in my Galaxy phone.
776188
Follow Up By: Member - Rod N (QLD) - Tuesday, Dec 11, 2012 at 10:41
Just to be pedantic, it actually D3. SBS moved to D3 a couple of months ago. C1 and D3 are co-located so the location figures are the same.
One thing to be careful of with the smart phone apps is that the LNB skew is not always correct for Ausie satellites. One finder I found to be good is included with Wikicamps.
776189
Follow Up By: bill - Tuesday, Dec 11, 2012 at 18:00
thanks guys, not my system, thrust upon me, with no detail, getting there though
776220
Reply By: Dennis Ellery - Monday, Dec 10, 2012 at 23:54
Bill the information you have given indicates a poor understanding of the basics – it will be difficult to instruct you over the internet.
Do yourself a favour – go to a caravan
park and pick out someone who has a disk set up and ask for a demo. Most travellers are glad to help.
500154
Reply By: Racey - Tuesday, Dec 11, 2012 at 09:27
Hi Bill,
Assuming the connections are correct and you are seeing the set top box logo etc on your telli, you may be pointing to the the wrong satellite. Optus D1 is close by at 160 deg East. You need to lock onto C1 which is 156 deg East. The basic analogue meter can be a little misleading for the novice. Other satfinders can be set to locate C1 only. Many on Ebay or try www.Satplus.com.au they are located on Nepean Hwy Edithvale. I get al my gear there. Philip is very helpful.
Racey
500171
Reply By: Phillipn - Tuesday, Dec 11, 2012 at 09:29
Try "Hills Gemine Satellite Dish Alignment Settings". It gives settings for all of Australia.
500172
Follow Up By: Phillipn - Tuesday, Dec 11, 2012 at 09:52
Also check out wanderingtews.com
and click on optus C1 satellite settings
Plus Vast digital
satellite TV.
776179
Reply By: Member - Brian P (SA) - Tuesday, Dec 11, 2012 at 18:31
Hi Bill. Is your vast set top box activated? It needs to be reactivated every 6 months. Merry Xmas Brian
500190
