Drawing lines on charts/maps .....
Submitted: Thursday, Dec 13, 2012 at 14:43
ThreadID: 99471 Views:2812 Replies:4 FollowUps:6
I use my Magellan 320 & OziEx to record and subsequently plot my track when yacht racing. I wanted to draw the Race Start and Finish Lines on the chart. It's virtually impossible to do this accurately using a drawing program. The best I've managed is to add the Start and Finish Line buoys to the chart as map features. Using Create Track Points, I inserted TP's on both sets of buoys and then displayed the tracks. That works fine but I have to load these for every race. Does anybody have a method of making accurate lines on charts which are permanent so that they load with the map file?
Reply By: Tim HJ61 (WA) - Thursday, Dec 13, 2012 at 15:48
Auntie Podes,
The answer will be found in opening the map image file, not the .map file and creating a line on that map. However, you're indicating you have tried this with a drawing program and it won't work.
Can you let us know what drawing app you have tried and someone with knowledge of how to draw a line in an image will be able to help.
On OSX, the free Preview app does this easily and you simply re-save the file as PDF, PNG, JPG or TIFF as you wish. No idea about PC applications, but assume they have something similar. If you save the map image file to a different name or format, you will have to recalibrate it when you import it back into Ozi. If you keep the file name and type the same, it should work fine.
Tim
AnswerID: 500288
Reply By: Shaker - Thursday, Dec 13, 2012 at 16:47
Wouldn't the start line be relaid for each race to allow for wind direction?
AnswerID: 500291
Reply By: The Explorer - Thursday, Dec 13, 2012 at 17:13
Hello
Two ways you could do this without modifing the actual image.
Create a track file of the lines you wish to diplay in Ozi and save it, then use "File - check calibration of map". In the Options section you can load a track file and then save the calibration file (*.map) which will then load the track file everytime that map file is opened.
Other way is to create a project in OziExplorer (use Options - Project Manager). With this function you can associate map and tracks (and waypoints etc) together as a "project" and then when you open the project all files are loaded together.
Read the help file for more specific instructions.
AnswerID: 500292
Follow Up By: Gramps - Thursday, Dec 13, 2012 at 17:18
Hahaha beat me to it Al.
FollowupID: 776342
Follow Up By: Auntie Podes - Friday, Dec 14, 2012 at 10:05
Thanks everybody ....
Tim - The problem was putting a straight line at the correct angle in the right spot with no ref points.
Shaker - No - the buoys are opposite the club house and semi-permanent.
Gramps - "Projections" doesn't look hopeful.
The Explorer (?Al?) has the solution - I've just tried it and it works a treat. I must now add all the race marks and buoys around the bay to save loading them every time.
Many thanks to all of you, and a great Xmas and New Year.
"Al" wins the prize!
FollowupID: 776377
Follow Up By: The Explorer - Friday, Dec 14, 2012 at 12:58
Al ?
Im lodging a protest ! I clearly crossed the line first :)
FollowupID: 776388
Follow Up By: Auntie Podes - Friday, Dec 14, 2012 at 13:37
Gee! Sorry Greg - yes you did win. I was confused by Grumps reference to Al.
FollowupID: 776392
Follow Up By: Member - wicket - Friday, Dec 14, 2012 at 14:16
Don't you just love how intuitive Oziexplorer is !?
FollowupID: 776393
Follow Up By: The Explorer - Friday, Dec 14, 2012 at 16:44
Auntie...no worries, its not a competetion:)
FollowupID: 776395
Reply By: Gramps - Thursday, Dec 13, 2012 at 17:17
Can't remember the details but pretty sure you can use the Project Manager function in Oziex to load Tracks, Map features, lines etc etc every time you load a particular map.
AnswerID: 500293
