3 Way fridge fan operation
Submitted: Sunday, Dec 16, 2012 at 19:18
barry22
I have installed a fan to my van 3 way 90 litre fridge. The fan does not seem to cut in early enough, despite quite a lot of hot air coming out of the vent. I believe the switching sensor from JayCar is set at 70 degrees. I am wondering if members have a similar concern, and perhaps have settled on a lower setting. What might be even better, is one that I can adjust to suit my installation ?? Any ideas ??
Thank you for your feedback, Barry
Reply By: The Bantam - Sunday, Dec 16, 2012 at 19:36
What sort of switch are you using....just a little bi-metalc switch?
70 degrees is fairly warm...you could go for a lower temperture switch.
OR
jaycar sell an automotive kit that allows very accurate temperature switching, if you are able to do electronic assembly.
I think they also sell an off the shelf ready built thermostat....not sure of the temp rangs thought.
500490
Reply By: olcoolone - Sunday, Dec 16, 2012 at 21:30
The hot air may not be coming from the condenser that you want to cool, 3 way fridges work by generating heat inside a furnace either by a flame when on gas or a heating element when on 12 or 240v.
3 way fridges struggle on temps above 32 deg C
500504
Reply By: Member - bbuzz (NSW) - Monday, Dec 17, 2012 at 15:46
I have installed two fans, with the thermostat attached to the top of the condenser fins.
I have found that the fans only turn off, when controlled by the thermostat, at night. As pointed out above, the heat buildup over 32'C causes this. However, I feel that the fans taking the hot air out help the fridge to work better anyway.
I will try to paste a doc to show you how I did it.
Bill
500543
Follow Up By: Member - bbuzz (NSW) - Monday, Dec 17, 2012 at 15:51
Nope. Didn't take.
Try again.
Fridge Fan Wiring
Hope it works.
bill
776593
Reply By: Member - Ann D (WA) - Tuesday, Dec 18, 2012 at 14:08
>Thanks Bill,
>Have heard about this modification,now I will be able to get the parts and have
a go myself.
Ann D.
500621
