D-Max potential problem.
Submitted: Monday, Dec 17, 2012 at 21:26
ThreadID: 99529 Views:3250 Replies:4 FollowUps:1
We bought the d-max new in Feb 2011, and have used it for 4wding it has done quite a few river crossings but only 2 were level with the bonnet.
Now the problem... yesterday my wife said " come here you have a problem" and she moved the rear left door back and forth quickly the sound of sloshing water was evident. It has a rubber plug / flap at the bottom and when I removed it the drain hole was blocked by plastic and silt. Cleaned it out and the water poured out Would pay to check your doors as one other of mine was blocked. Can only assume the plastic was from manfacture.
Cheers warren
Reply By: member - mazcan - Monday, Dec 17, 2012 at 22:08
hi
guess you have to expect that when you use your vehicle like a submarine
i dont really think it is any fault of d/max
it can happen to any brand if you submerse them
AnswerID: 500583
Follow Up By: Axle - Tuesday, Dec 18, 2012 at 09:43
Ditto X Ten.
FollowupID: 776629
Reply By: Member - Noldi (WA) - Tuesday, Dec 18, 2012 at 12:37
Good point Warren, pays to check, thanks for the reminder
AnswerID: 500617
Reply By: escapesilv - Tuesday, Dec 18, 2012 at 17:10
Hi Warren
Very good point, will check mine before we leave on our next trip, its something we don't consider.
Rob
AnswerID: 500631
Reply By: Lachy T - Thursday, Dec 20, 2012 at 20:30
I had a second hand 2006 rodeo before my GU and we never did a river crossing in it. It used to get some water in the doors when it rained and was parked facing down the hill, due to the drains being on the back side of the doors. This was caused by the seals around the electric windows leaking. Holden dealer who I bought it off replaced all the seals under warranty. But goes to show that it can come in through some strange places.
AnswerID: 500770
