innamincka to rig rd
Submitted: Saturday, Dec 29, 2012 at 16:03
ThreadID: 99688 Views:2196 Replies:3 FollowUps:0
Has anyone any current info on the Innamincka to Rig Rd ending up at Dalhousey Springs
Cheers Les
Reply By: Ozrover - Saturday, Dec 29, 2012 at 16:38
Yeah!
The Rig Road in the Simpson Desert regional reserve is closed until the 16th of March 2013.
Read the road reports for the area!
Witjira National Park is open all year round.
AnswerID: 501216
Reply By: Member - Phil G (SA) - Saturday, Dec 29, 2012 at 20:22
What are your plans, Les?
AnswerID: 501223
Reply By: Member - Stephen L (Clare SA) - Saturday, Dec 29, 2012 at 20:52
Hi Les
One would presume that you are planning a trip for the cooler 'southern winter' months when travel conditions are at their peak.
The problem with the route that you are planning (I presume which way you want to go) has been closed now for a few years due to water damage and water closing the Warburton Crossing.
I know from friends that are working up in the Cooper Basin that yes the Walkers Crossing bridge has been repaired, but only usable for workers in that area. It is the same as the track going off of the Birdsville Track and through the Warburton Crossing. The crossing has been closed as it is steep and the body of water throughout the crossing puts a halt to all vehicles. Even if the crossing is open, there are many kilometres of flat, black soil tracks and you only have to spit on them as such and it turns into a very boggy track.
I will now give you an idea of what it is like when things are good. The drive from Innamincka through Walkers Crossing and out to the Birdsville track is a good drive, but take note of your bearings if you do not run Ozi, as there are many good tracks in the lower section used for the gas operations and it is easy to take the wrong track. A comfortable drive will take around the 6 hour mark or longer if you stop regally to 'smell the roses'. The final section (around 20 kilometres or so) out to the Birdsville Track is at a slower pace, due to the very rocky condition of the track.
The K1 Line in from the Birdsville Track is not signposted, so you will have to have either waypoints or a very good idea where it branches off. In dry times, it is a very easy drive, with only a few very small dunes that can catch out the unexpected. The dunes in this southern section of the Simpson are white and are a complete contrast for when you get further into the desert. Like I said, apart from a couple a small dunes, the drive is very flat and a good 2wd track. Again if you intend to follow the full length of the Rig Road, you will need to know where it branches off of the K1 Lines. The very first dune heading into the Rig Road can at times be a very good christening into sand driving, and has caught many drivers out.
The Rig Road is different to the other 2 main tracks heading west, but again it is a good experience to drive the Rig Road.
Like above the desert is closed for safety reasons, and has been this way for the last few years.
When conditions are good, you will enjoy the contrasting drive.
Cheers and Happy New Year.
AnswerID: 501226
