LOGIN WOES
Submitted: Tuesday, Jan 01, 2013 at 22:50
Member - reggy 2 (VIC)
Hi all
When I start up this site I have to log in every time
The site does not seem to remember the Log in it used to last about a week before it changed.
Is there something I can do other than just click the remember me box.
Thanks for any help.
Reply By: ModSquad - Tuesday, Jan 01, 2013 at 23:27
Hey there, That should work, but maybe theres a profile issue with an old login, we shall send this off to the sleuths to take a look.
Tha Squad
501423
Reply By: ExplorOz - David & Michelle - Wednesday, Jan 02, 2013 at 12:12
Reggy 2,
Firstly lets clear out your ExplorOz cookies and reset them and see what happens. Logoff the site (or visit the site in logged off mode) then open the Login tab - on this tab in the RHS is a button called Clear ExplorOz Cookies - click this. This will report on the number of EO cookies that have been removed. Then login again as normal with remember me enabled. let me know how you get on.
David
501444
Follow Up By: Member - Scrubby (VIC) - Wednesday, Jan 02, 2013 at 19:58
G`day David,
I have exactly the same problem, tried your suggested remedy above a few times with no result.
I don`t bother to login most times because of this little hassle.
I think it started about the same time that you added the FaceBook etc,login feature.
Regards,
Scrubby.
777615
Reply By: Member - Mike R2 - Wednesday, Jan 02, 2013 at 20:02
Gooday, I have the same problem so do not often log on , look at the site most days. Also seems on some occasions to take a long time to redirect. Otherwise love the site.
501469
Follow Up By: Fiona & Paul - Wednesday, Jan 02, 2013 at 21:25
G'day Mike
I have just moved to Win 8 and going through the processes of re-establishing all my login data. I often got into trouble here because of my own stupidity more often than not, so I tested all of the above logging in and out, removing cookies and all worked the best it has ever worked for me.
All the best for 2013.
Paul H
777625
Reply By: Member - Mike R2 - Thursday, Jan 03, 2013 at 09:48
Thank you Paul, I'm hopeless with these electrical devices
Mike
501509
