Cub camper tent problems
Submitted: Friday, Jan 04, 2013 at 17:32
ThreadID: 99794 Views:6007 Replies:5 FollowUps:4
I found an old forum thread re problems getting the tent to set properly on Cub Campers. 2013 and I still have the same problems with my Cub escape which I have owned for 3 years. The company are happy to reset it but it never stays reset.
As in the previous forum thread I have given up. However I have now found that I can tie the back out (to a tree or post) using the eyelets on the back of the tent and straighten it up! This is wonderful as I am now able to zip the door up easily.
Are others still having this problem?
Reply By: Life Member - Phil B (WA) - Friday, Jan 04, 2013 at 20:08
Hi Ray
I'm having same problem with my drover - most frustrating.
What do you mean 'tie the back out '?
AnswerID: 501667
Reply By: Wilko (Parkes NSW) - Friday, Jan 04, 2013 at 20:39
Hi Ray,
Its a bit of an art to get the tent to be taut but once youve mastered it, its easy. Ive found the biggest prob is camping on uneven ground.
Cheers Wilko
AnswerID: 501670
Follow Up By: Ray Ferg - Friday, Jan 04, 2013 at 21:54
Hi Wilko,
I understand it may be an art but boy its frustrating. My problem exists on very flat ground.
Cheers Ray
FollowupID: 777876
Reply By: Ray Ferg - Friday, Jan 04, 2013 at 21:59
Hi Phil
I will put up a Picture ASAP to show you my solution. I plan to get a couple of very large tent pegs or steel fence posts to use when I have no "trees".
Ray
AnswerID: 501679
Reply By: Ray Ferg - Friday, Jan 04, 2013 at 22:49
Sorry I cannot figure out how to upload pictures from my computer
Ray
AnswerID: 501683
Follow Up By: Life Member - Phil B (WA) - Saturday, Jan 05, 2013 at 22:14
Thanks anyway Ray,
I'll keep in mind your suggestion and see if I can get it to work next time my set up gives me grief
FollowupID: 778006
Reply By: lindsay - Saturday, Jan 05, 2013 at 18:18
Make sure the fold out floor is set up properly and that the 2 edges at the back are the same distance apart. Zip the door up before you tension the tent. Look for ripples and adjust as necessary to get the ripples out. Quite simple once you get the knack.
AnswerID: 501761
Follow Up By: Life Member - Phil B (WA) - Saturday, Jan 05, 2013 at 22:12
Thanks Lindsay
I'll try zipping up first then tensioning tent.
FollowupID: 778005
Follow Up By: Scoof - Monday, Jan 07, 2013 at 14:56
I have a cub camper also and had the same trouble with the door. I took it to the local canvas bloke to have the zip fixed and he set the camper up. The door zipped up better than ever and he was the one that told me about making sure the door is zipped up closed when setting the camper up. Such a simple thing that you just don't give a thought to.
Now after 10 years it's better than ever.
Scoof. :-)
FollowupID: 778220
