Rubber intake hose repair
Submitted: Saturday, Jan 12, 2013 at 13:12
ThreadID: 99949 Views:6627 Replies:8 FollowUps:7
I have a rather large split/crack in the rubber hose between my air box & alloy intake pipe that sits across my engine (1HZ). Anyone know the best way to fix this? I was thinking about sikaflex but wanted to check if someone has had success with it first.
Josh
Reply By: Member - MUZBRY(Vic) - Saturday, Jan 12, 2013 at 13:26
Gday
The best thing to do is buy a new one.
AnswerID: 502354
Follow Up By: member - mazcan - Saturday, Jan 12, 2013 at 13:30
hi
x 2 its an important part replace it
FollowupID: 778760
Follow Up By: olcoolone - Sunday, Jan 13, 2013 at 09:07
x 3
Why try and cut corners on a critical part...... a few $$$ (hundred) saved now might be a few $$$$$ (thousand) lost later.
Shake head in disbelief.
FollowupID: 778835
Reply By: Lucko - Saturday, Jan 12, 2013 at 13:29
Give the Emergency Tape a go. Worked well for me on the Patrol intake hose. Still there after 3 years.
Mark
AnswerID: 502357
Reply By: Aussi Traveller - Saturday, Jan 12, 2013 at 13:40
This took me 10 seconds Air intake hose
AnswerID: 502359
Reply By: Member - Jack - Saturday, Jan 12, 2013 at 16:25
Easily replaced. I did so on my 80 Series. You will find the silicone 'Rescue Tape' will give you a good temporary repair in the meantime. Normally available from Jayco Stores.
Jack
AnswerID: 502369
Follow Up By: olcoolone - Sunday, Jan 13, 2013 at 09:09
I knew Jayco vans were bad but I didn't know they sold a rescue tape for them......
FollowupID: 778836
Reply By: ironJosh - Saturday, Jan 12, 2013 at 18:25
I'm more looking for a temporary fix, as the old girl is getting a turbo soon.
AnswerID: 502382
Follow Up By: Rosss - Sunday, Jan 13, 2013 at 10:00
Yeh, Tape it up and save a heap of money on the turbo, when it sucks a gut full of dust past the tape it won't be worth putting a turbo on.
FollowupID: 778839
Follow Up By: ironJosh - Wednesday, Jan 16, 2013 at 14:10
They fit a new hose when it gets a turbo.
FollowupID: 779193
Reply By: Hairy (NT) - Sunday, Jan 13, 2013 at 13:14
Gday,
Wrap it up tight in "3M Scotch self amalgamating tape". Give it a squirt of Aero start while your engine is runnung to check for leaks and check it before you drive in any dust......it will last for months.....if not years.
AnswerID: 502420
Reply By: Member - mechpete - Monday, Jan 14, 2013 at 10:56
whats cheaper ????
new hose ?? dusted engine ????
pretty easy decision really !
mechpete
AnswerID: 502510
Reply By: landseka - Monday, Jan 14, 2013 at 11:22
Considering this..." ironJosh
I have a rather large split/crack in the rubber hose between my air box & alloy intake pipe that sits across my engine (1HZ)."
....one could suggest that as "split/cracks" don't appear overnight whilst parked the car has already been driven, perhaps for some time with said "split/crack" in place. Maybe any damage that may be done has already been done?
Cheers neil
AnswerID: 502516
Follow Up By: ironJosh - Wednesday, Jan 16, 2013 at 14:11
I damaged it when I while taking it off to get to the cam cover.
FollowupID: 779194
Follow Up By: landseka - Wednesday, Jan 16, 2013 at 14:14
Aha, that explains it........lol
FollowupID: 779195
