Monday, Jan 14, 2013 at 21:46
bazooka mate that is exactly why people wear out their syncros a head of time.
There is no reason that any gearbox should need the syncros changed for the life of the vehicle....but plenty do
Accelerating hard and skip changing IS a waste of fuel.
The asumption that the average joe does no know how to drive is a pretty safe one...and proven every single day.
The vast majority of syncro box drivers will have no idea of matching revs when changing gears and will have not the faintest idea of how the syncro rings speed or slow the selecting gear so it does not grind
In a pasenger car or light commercial, driving sequentially thru the gears IS the most efficient.....it is certainly the fastest when driven hard.
If you subscribe to the gears are for going and brakes are for stopping...there is no reason to down shift at all untill you are to power on....but you will spend a lot of time coasting, which is bad practice and you will often be caught in the wrong gear.
But if you subscribe to the view that you should be in the right gear for the road speed at all times, its a different strory.
Skip changing on down shift is hard on syncros...no question about it.
Most people who do, it is simple straight forward lazyness.
779050
