long range fuel tank and suspension
Submitted: Wednesday, Feb 20, 2013 at 09:18
Member - Danielle h
we are in Victoria and are looking to remove the injected gas system off our 80 series and put on a long range
tank. half the
places we travel do not have gas and if they do the price is the same as petrol so we figure as it is not a daily driver remove it. Can anyone recommend a good company and roughly what they paid I know of brown davis and arb and longrange just want peoples thoughts on who they have used and their experience with the particular
tank they have. also what do people recommend for
suspension does it need an upgrade we have new shocks it is lifted but springs may need replacing we are not towing anything. thanks in advance
Reply By: Mick O - Wednesday, Feb 20, 2013 at 10:33
Danielle, there is ample on these two topics and the manufacturers you have mentioned if you search back through the
forum. Having said that I prefer a company that make their own product and will therefore stand by it. In that case your choices will be Long
Ranger automotive and Brown Davis. ARB peddle products produced by others under their own badge and are very reluctant to stand by the product once it stuffs up,
fuel tanks in particular. My advice, great for bull bars and bar work but steer clear re
fuel tanks. I’m not enamoured of their
suspension products either having seen far too many of the OME products fail once the going gets tough (and all outback tracks are tough these days due to corrugations.
One stop
shop for both
tank and
suspension leaves you Brown Davis – Their tanks are of good quality and they will stand by their products. They will do
suspension works for you at the factory using the manufacturer of your choice. I’d recommend Tough Dog but again, your
suspension choice should be based on your needs and research.
Have a look here under the “Getting Stuff done” heading.
Ute build - Brown Davis
Cheers Mick
505157
Follow Up By: Member - Chris (QLD) - Wednesday, Feb 20, 2013 at 18:36
Hi Mick,
I don't know about all the tanks supplied by ARB but the one I purchased from them for a Nissan D40 was an LRA
tank, it came as a complete kit all marked LRA, no ARB branding to be seen.
The
tank was
well made, very good fitting kit with all instuctions.
Chris
782133
Follow Up By: Mick O - Wednesday, Feb 20, 2013 at 18:52
Hi Chris,
just to be sure are we talking the Longranger tanks of Queensland as supplied by ARB see here;
The Longranger
or "Long Range Automotive" as in the
fuel tank manufacturing company of
Croydon; See here:
Long Range Automotive - LRA
I have owned both, having had an LRA product in my D20 Navara and an Longranger in my Patrol. If you had an LRA product you have done exceptionally
well as Roger and the boys at
Croydon do good work. Their tanks are
well made and strengthened and they provide excellent after sales service.
When the other product failed in my Patrol, ARB didn't want to know about it. I ended up having Brown Davis remove and gusset it and strengthen all the corner points with pacmen.
Cheers Mick
782136
Follow Up By: Member - Chris (QLD) - Wednesday, Feb 20, 2013 at 19:32
You started me thinking Mick, so I had to check, found an email reply from the manufacturer when I had a query.
The
tank was definently an LRA (Long Range Automotive) and purchased through ARB on the Sunshine Coast.
Maybe at the time Longranger did not make a
tank for the D40?
Chris
782138
Follow Up By: Mick O - Wednesday, Feb 20, 2013 at 22:02
You're probably right Chris. Either way you have a very good
tank in one from LRA.
782160
Reply By: Member - nick b - Wednesday, Feb 20, 2013 at 13:52
Reply By: Member - Danielle h - Wednesday, Feb 20, 2013 at 20:49
thanks all for your advice - much appreciated, spoke with long range automotive on the weekend at a four wheel drive show might look at going through them
505211
Reply By: Ross M - Wednesday, Feb 20, 2013 at 21:06
Danielle H
I was under the impression some of the 80 series had two tanks. If you fit a large long range unit all the
fuel and all it's weight is in the one container.
On one of the forums an owner had to remove his long range
tank on one of the popular tracks and reweld the brackets which held it in. Not common but definitely a pain in the armpit.
If you have a main and a sub
tank then all your
fuel eggs aren't in one basket case if one of them fails.
Possibly worth investigating if this
tank setup is available from wreckers.
May be a few around as many have fitted BIG LR tanks.
Just depends on how much
fuel you need to carry.
Ross M
505213
Reply By: Member - John - Thursday, Feb 21, 2013 at 06:58
Where abouts in Victoria are you? If near the outer south east of
Melbourne, can recommend Grge Smith, Smithies Outback Gear in Cranbourne for
suspension advice and fitting, as
well as
tank fitting. Agree, LRA tanks are a good product. Greg will give you all the options and not try and push you towards one brand or an other. He can be contacted on 03 59954325 Premise is at 1/218 High St Cranbourne
505226
Reply By: Member - Danielle h - Thursday, Feb 21, 2013 at 17:31
thanks John and julie spoke to him this morning and he was great we live about 5 minutes from cranbourne - did not know he installs tanks though and he did not mention that he did he gave me advice on
the springs we need so will speak to the husband and might get a price on the
tank installation from greg too thanks again
505249
Reply By: Echucan Bob - Friday, Feb 22, 2013 at 09:39
Danielle,
from your comments it appears you view the gas injector as purely a cost saving device. I find that it improves power, torque and
fuel economy. It also increases range.
Unless it is programmed correctly, you won't achieve these benefits. It might be worth having it assessed and measure the parameters I mentioned before committing to the costly course of replacing it with a LR
tank (and associated
suspension mods).
I also go
places where gas isn't available. In these situations I turn the gas off until I need the extra power/torque for a tricky dune etc. Using the gas makes getting to these remote
places far more economical (eg the drive from Victoria to say
Alice Springs).
My 20L gas
tank lasts as long as the 120L
fuel tank, but improves range by a lot more than an extra 20L of diesel.
I love the gas injection system. I'd urge you to fully explore its benefits before making a an expensive and rash decision to dump it.
505286
Reply By: Matthew G3 - Friday, Feb 22, 2013 at 13:44
Hi Danielle
I have an 93, 80 series with a 170ltr
tank in the back [265 all up] by Longranger [ARB] ive had it in for 16 years with no problems. The best on road at 110kmh ive got is 1265kms from the 170. I run ARB springs at 400kg above standard with poly air bags just to take the bownce out on h/way, but i do have a twin carrier on the back and rear draws. I had nothing but trouble with ARB shocks. For a heavy stiff vehicle which i have done the Cape around the gulf to
Darwin,
Googs Track, Simpson, all fully loaded with no cracking fatigue problems.
I have the matching springs in the front but i do have a high mount winch + bar+ side rails+ the d/b.
505309
