I'm just starting out - what should I aim to get?
Submitted: Saturday, Apr 06, 2013 at 21:08
Holly R
This week, we bought a 2009 Nissan X-Trail T31 ST. We're just getting into 4 wheel driving and are looking forward to taking it out this weekend.
Since we've never done it before, I'd like to know what gear I should have before setting out anywhere. What is the essential recovery and safety gear we should take?
We won't be going very far, maybe 20 kms from civilisation, but I'd like to be prepared.
Also, if anyone could offer any tips or advice, that would be fantastic.
Thanks,
Holly
Reply By: equinox - Saturday, Apr 06, 2013 at 21:16
Hi Holly,
For starters - I suggest a shovel, an axe, a plank of wood or two for both a jacking base and a mud filler, and a decent jack - and even though 20 kilometres is not very far away from civilization, I suggest taking more
water than what you would think you would need.
508359
Follow Up By: Holly R - Saturday, Apr 06, 2013 at 21:31
Thanks! Sounds doable. We have all those things in the shed so we're all set.
We also have a 10L
water holder, so we'll take that too.
Thanks again.
785869
Reply By: Member - John - Sunday, Apr 07, 2013 at 05:24
Good morning, I would be taking a good map of the area you are going to visit.............. Enjoy your travels. John
508377
Follow Up By: Holly R - Sunday, Apr 07, 2013 at 20:24
Yep. We have a good collection of maps so that will be easy. Thanks.
785966
Reply By: garry r - Sunday, Apr 07, 2013 at 06:43
have fun be patient and above all a good sense of humour. Don't lets youself be stressed.
cheers garry
508378
Follow Up By: Holly R - Sunday, Apr 07, 2013 at 20:25
As with a lot of things, I suppose. You get nervous when you get stressed, too.
785967
Reply By: Member - MUZBRY(Vic) - Sunday, Apr 07, 2013 at 07:30
Good morning
Gee ,I would like to have a 4x4 track that close to home .
508380
We live in a rural area so it's not very hard to find tracks around. We're lucky!
785968
Follow Up By: Member - MUZBRY(Vic) - Sunday, Apr 07, 2013 at 21:50
Good evening Holly
Just send us all your address and we will bring a dozen vehicles up for the weekend . Only joking
785979
Reply By: Member - Russler - Sunday, Apr 07, 2013 at 08:27
Add a
UHF radio. At least you may be able to call for assistance if you get stuck. But another UHF needs to be in range, so don't rely on it.
Hope you have a lot of fun.
508382
Follow Up By: Holly R - Sunday, Apr 07, 2013 at 20:28
We're definitely going to invest in one in the future. Right now we're not going anywhere isolated, so it's on the list but not at the top.
Thanks.
785969
Reply By: Life Member-Doug T NSW-Ex NT - Sunday, Apr 07, 2013 at 08:29
One of the best to take with you is common sense.
and go where others go (within reason) and watch and learn.
508383
Follow Up By: Member - Fab72 (Paradise SA) - Sunday, Apr 07, 2013 at 08:47
...and patience.
You'll be able to get out of most situations if you're patient and think things through.
Invest in a snatch strap and some load rated shackles. People don't mind snatching you out most times if their using your gear. A fire extinguisher or two and a
first aid kit.
Also do some research on the type of vehicle you have. It's strengths and weaknesses. For instance, when I was looking to by my 4by, I considered an X-Trail but read up that the factory air intake is quite low so avoid deepish
water crossings for the time being.
Google is your friend!!!!
Fab....
785897
Reply By: Lyn W3 - Sunday, Apr 07, 2013 at 09:03
First safety item for us is our PLB.
Never know when or where you can have an accident and be trapped or injured.
You will probably never use it but its nice to know its there,
508390
Reply By: Member - John and Val - Sunday, Apr 07, 2013 at 09:21
Hi Holly,
Congrats on your new purchase and may you have many happy adventures in it. Suggest that fairly soon, after you have got to know your vehicle a bit, you would get good benefit from a good 4WD course. Many 4wd clubs run these.
In the meantime, when you come to a point on a track where you are uncertain about how to proceed - stop, get out and walk that section of the track and ask yourself "do I need to do this/go there?" If the answer is no, then its time to turn back.
Take it easy, get to know your vehicle before trying to be too adventurous and you will have a great time.
Val.
| J and V
- Albert Einstein
508391
Reply By: pop2jocem - Sunday, Apr 07, 2013 at 09:23
The list of recovery and safety gear you could take is almost endless and you will add bits and pieces to suit your own particular needs and circumstances as you go and learn.
To what has already been suggested I would add a good quality and capacity 12 volt air compressor and a tyre pressure gauge. It's amazing what you can drive straight out of with reduced tyre pressures but you will need to be able to re-inflate before you hit the bitumen again.
I would also suggest a basic
first aid kit and maybe join a 4WD club if you are just starting out.
Safe and happy travels
Pop
508392
Reply By: HarryH - Sunday, Apr 07, 2013 at 10:25
I always go bush with at least one other 4by and you'll want to make sure you have at least one proper recovery point front and rear(or a tow bar at rear), no point having all the recovery gear but nothing to attach it to. Not sure about the X-Trail but some (lots) 4wds come from the factory with tie down points that can often look like a good strong recovery point but will rip straight off when snatched from a difficult recovery so id be looking into that first up.
Good luck and have fun :)
508400
Reply By: allein m - Sunday, Apr 07, 2013 at 11:01
when you get a bit more confidence come out to
Broken Hill and you will find many many place to see off road but several golden rules if you come out this way because of it remoteness we have limited
mobil phone service so if some thing goes wrong stay with the car and let people know where you are going and expected time of return this was brought to a point only 4 weeks ago two old timers from
broken hill went out to a remote property only to break down one sadly died during the wait for help but they were found very quickly because they stay with the car sadly there was one two years ago he left the car and they found his body 18 months later dead enjoy your travels where ever you go
508403
Reply By: Patrol22 - Sunday, Apr 07, 2013 at 19:21
Someone has pointed out the need to understand the capabilities of the vehicle and I would back this recommendation. Fundamentally the X-Trail is what is known in the broader 4WD community as a "soft roader"- basically meaning that it does NOT have a transfer case and low range capability. That is not to say that it is not a very capable vehicle, it is. But the vehicle will not be able to handle the same sort of country that a Patrol or Cruiser can.....and this is especially so in steep country. I would suggest that you join a 4WD club or do some proper 4WD training.....DO NOT accept the advice of the Nissan salesperson in respect of the off road capability of this vehicle on face value - the vast majority of salespeople are not competent off road drivers.
This aside I know you will enjoy the X-Trail withing the limits of its capability. It is especially good on
the beach and in the
sand dunes.
508429
