Saturday, Apr 20, 2013 at 22:53
HI Paul
The essentials for best operation of a 3way are:
[1]Adequate wiring from the TUG battery ALL THE WAY to the fridge with NOTHING else on that circuit
You require the design voltage for them to generate the necessary heat in the boiler
THAT means you require MIN 12V at the fridge terminals WITH THE FRIDGE RUNNING
& the vehicle alternator inputting to the crank battery [medium idle speed]
If you are not getting at least 12V, the CABLES ARE undersized[as usual]
['2]the fridge does draw a high current & should only be on when the engine is running
This can be achieved by either a "Fridg Switch"[motion sensor]or an ignition controlled relay switching the POS line to the fridge.
[3] Very few 3WAYs are installed to the fridg maker's instructions
This particularly includes the ventilation a baffling at the rear to get the best possible cooling air flow through the fridge CONDENSER
If you do a bit of MR GOOGLE search for "3way fridge fans " "3way fridge baffles"
& similar you will see loads of proven methods,
or come back here & I will give more lengthy details
[4]The charging circuit to the VAN house batteries should be an entirely SEPARATE circuit from the tug battery,to achieve BEST charging of the house batteries
[5]A compressor fridge is great IF you have the means of keeping the batteries charged
That needs a lot of consideration & just how much Solar &/or battery capacity you will need depends on your
camping style & fridge temp settings
then you have to decide what you would do if a run of overcast /rainy days set in & you got little solar input
But IF you only used powered sites then a comprressor fridge would be excellent
I myself have both & although I have 200W of solar & 200Ahrs battery capacity
I am often glad I have a 3way
Give it a lot of thought !!
PeterQ
electrician
509419
