plug and play
Submitted: Sunday, Nov 03, 2013 at 22:07
ThreadID: 104976 Views:10093 Replies:4 FollowUps:3
Anybody had any experience with plug and play UHF's?
Something like this.
http://www.ebay.com.au/itm/GME-TX3100-ANTENNA-PORTABLE-PLUG-N-PLAY-80-CHANNEL-UHF-CB-RADIO-5W-80CH-MOBILE-/331057262153?pt=AU_Electronics_Radio_Equipment&hash=item4d148cee49#ht_3241wt_970
Take it in or out of car as needed. Or move to another.
Looking for a new set. Found this type, but also considering one of those small units where all the controls are on the mic.
Thanks for any comments
Reply By: rocco2010 - Sunday, Nov 03, 2013 at 23:47
Gidday
Hired something similar many moons ago, worked fine In a convoy situation with a stubby aerial on a magnet base on the roof . Obviously you get better range with permanent aerial but was not an issue for me at that time. GME is a reputable brand used by lots of people. Only issue I can think of is that you will have a few cables running around which you don't have with a permanent install.
AnswerID: 520816
Reply By: Nomadic Navara - Sunday, Nov 03, 2013 at 23:52
It looks just a standard TX3100 mounted on a stand similar to a navigator or phone unit and a very short antenna. The antenna is only 2.5" long so I don't have much faith in its efficiency.
You could make up the same sort of kit with any CB radio, just add a mounting and a power lead with a cigarette lighter plug.
I would be more inclined to use a portable radio with an external antenna mounted on the vehicle. That way you could have a radio to use elsewhere and a decent antenna for when you are on the road.
AnswerID: 520817
Follow Up By: Ross M - Monday, Nov 04, 2013 at 09:25
One of my UHF's is a magnetic base aerial and either a GME handheld or TX3100 both powered from a ciggy lighter plug. Now they are offered as PLUG & PLAY.
WE know it as , Make Your Own and use. Been using it for 10 years with different radios.
FollowupID: 801380
Reply By: Sand Man (SA) - Monday, Nov 04, 2013 at 07:21
I agree with Peter.
Something like a GME TX6150 ($256 from Prestige Communications) and a magnetic base external aerial will give you the better result.
Have dealt with Prestige on a few occasions and their prices and quick dispatch are hard to beat.
GME TX6150 5 watt 80 channel CB Handheld Transceiver
GME Magnetic Base 6DB 900mm Antenna
Note: If mounting the magnetic base on the roof, you could choose a shorter antenna to screw on to the base. A 900mm one may be a bit long and unnecessary.
Bill
AnswerID: 520823
Follow Up By: Winner W - Monday, Nov 04, 2013 at 08:42
I have a TMX 3100 plug and play. Love it,works fine, If I dont use it it fits in a small bag under seat. I dont even put the antenna on roof. Its base sits under the dash mat and the suction cap is strong to keep it on window and I use a hair elastic band to keep mic rattling around. This way I agree the range will be less but still good for many kilometers.
FollowupID: 801379
Reply By: MEMBER - Darian, SA - Monday, Nov 04, 2013 at 09:23
In my view, a 5W handheld ticks more boxes than the P&P option....and prices have obviously come way down for the quality 'Oz made' GME unit*..... it even has both fast and slow chargers.......my 6100 40channel kit was way more than that years ago and it was a show special.
*no affiliation.
AnswerID: 520831
Follow Up By: Winner W - Monday, Nov 04, 2013 at 12:59
I agree, if I had to buy now for the same price I would buy the handheld 5 w before the plug and play.
FollowupID: 801387
