Review: EOTopo
My Shop Item Rating: My Rating 5/5
Now have EOTopo running on my laptop - straight install and all went well
Getting it to run on a VMS 7000 dash unit took a little longer.
I had to update the version of OziExplorer CE on the VMS device. It then ran well and looks great.
A great product and will be eager to see updates in the future.
Reply By: Member - Michael W14 - Sunday, Nov 17, 2013 at 10:41
I had a look at the demo and all my spots were much clearer when I zoomed in than they were using the Natmap 250 maps.
I ordered it this morning.
Willie
Sydney
200 TD and Bushtracker 16'
AnswerID: 521584
Reply By: Member - Greg N (QLD) - Sunday, Nov 17, 2013 at 14:53
I have OziExplorer on my Samsung tablet with maps on a 32GB micro SD card. If I purchase the EOTopo maps, can I simply copy them to that card for use by Ozi? Thanks.
AnswerID: 521597
Follow Up By: Member - Alan H (QLD) - Sunday, Nov 17, 2013 at 19:02
You probably have oziexplorer CE on your tablet.
The maps just copy across no problem.
If it fails to run, check that the version of OziExplorer you have is the latest.
If not, just download the update from Ozi Explorer site.
As noted above mine would not work on the old version but once updated, it runs very well.
FollowupID: 802326
Follow Up By: ExplorOz - David & Michelle - Monday, Nov 18, 2013 at 11:50
Greg,
Alan is perfectly correct on this, EOTopo was sent out using the latest OZF converter from OziExplorer and this has a requirement to use later versions of OziExplorer. On the SD card is also full copies of the ECW files so you are able to convert again if you need to however we put a lot of work into tuning the OZF converter to give you a really good quality map.
If you have any problems please let us know and we will gladly sort it.
David
FollowupID: 802385
Reply By: Member - Greg N (QLD) - Tuesday, Nov 19, 2013 at 21:14
Have ordered my EOTOPO so will be able to say more at a later date.
AnswerID: 521740
