Comment: EOTopo 200K
Submitted: Tuesday, Jan 14, 2014 at 18:26
Member - JDR11
If I purchase
EOtopo 200k to run with Oziexplorer software on a VMS unit do I get the map files that will run with MemMap on an iPad? The way the info reads is that for MemMap you have to down load it via MemMap. Cheers JDR11
Reply By: ExplorOz - David & Michelle - Wednesday, Jan 15, 2014 at 19:18
JDR11,
You have read the documents correctly the Memory-Map version is separate to the SD/USB product. So if you want Ozi go with the SD/USB if you want Memory-Map get that version - you can reduce the license on MM to a 2 mobile license for less.
If you want both then the only option is to get both at this stage.
David
524573
