Which Vehicle and set-up to use
Submitted: Thursday, Jan 30, 2014 at 21:32
ThreadID: 106019 Views:5009 Replies:13 FollowUps:13
Hi All.
I am new to the forum, Selling house and going exploring, Firstly i have had experience in 4wd owning several , hilux, 80 series, navara and yes even a suzuki but has been a few yrs,
I am intending to travel from Tasmania thru the centre to Darwin perhaps then to the cape ( if i can tag along with another group) or partial there, then back down the East Coast,
Questions to be asked and replies greatly appreciated
Vehicle fuel type : diesel or petrol/gas conversion, - Thinking obviously gas would be hard to find in places.
Type of vehicle recommended, Loved the 80 series or even 100-105 but thinking a Patrol or Navara 3l diesel turbo
Option recommended. winch. How many spares, air compressor .spare fuel, water, 240v converter etc etc
Now i was alos thinkng of a roof top camper enstead of a camper trailer, obvious thoughts in regards to towing , tracks that may be used etc, Having no experience with these was hoping if anyone could share for;s and againsts for these.
Sorry for the many questions, unfortunately i am sure i have a few more,
All comments suggestions etc would truely appreciated
Tony
Reply By: Member - Scott M (NSW) - Thursday, Jan 30, 2014 at 22:17
Hi Tony, welcome to the forum. Fantastic idea to hit the road.
As to your questions, my 2 cents worth follows, others will probably disagree with some of it, but it'd be boring world otherwise.....
"Vehicle fuel type : diesel or petrol/gas conversion, - Thinking obviously gas would be hard to find in places."
diesel or petrol ? - much of a muchness, however diesel is safer to carry and probably a 'bit' cheaper in the $ per distance equation .... gas is rarer in remote places, so would avoid it
"Type of vehicle recommended, Loved the 80 series or even 100-105 but thinking a Patrol or Navara 3l diesel turbo"
subjective this one - your options would be capable for what you want to do .... my personal opinion .... you can't kill an 80 series diesel, probably the simplest and most bullet-proof of the lot, but getting long in the tooth - well maintained diesels are still a great vehicle
"Option recommended. winch. How many spares, air compressor .spare fuel, water, 240v converter etc etc"
personally? - I wouldn't bother with the winch unless money is no object - I know a lot of people who have fitted one and never used it in anger and unless you're doing mountain goat driving .... as to the rest of what to take - could go on for pages, however your best bet is to read this guide on this site and ask specific questions:
http://www.exploroz.com/OntheRoad/Camping/WhattoTake.aspx
"Now i was alos thinking of a roof top camper enstead of a camper trailer, obvious thoughts in regards to towing , tracks that may be used etc, Having no experience with these was hoping if anyone could share for;s and against for these. "
I've had 2 roof-top campers (an Open Sky fold out and the current Maggiolina) and I love the things ... easy to put up and down, all your bedding is up and out of the way, don't have to tow, no putting up tents on crappy ground and hammering pegs, up above any water/crocodiles etc. - get more of a breeze up high...
but in the interest of balance - a few of the negatives:
1. you have to reasonably level your vehicle - in 95% of cases this isn't an issue, and to some degree you have the same problem with a tent
2. you have to pack them up if you plan to drive anywhere - choosing one (like a Maggi or a James Baroud) and packing up is less than 5 mins work so I personally don't see this as an issue
3. the ladder - if you don't like climbing or you need to get up every 20 mins for a leak, it obviously will be a pain
I've had some people come up to me and say they don't like them because of the weight up high, and then will quite happily strap a spare tyre, and 4 x 20 ltr jerry-cans to the roof !!! - check the specs yourself - they don't weigh that much.
Otherwise - happy travels !!
AnswerID: 525433
Follow Up By: Member - Scott M (NSW) - Thursday, Jan 30, 2014 at 22:24
Follow Up By: Toney - Thursday, Jan 30, 2014 at 22:32
Thanks Scott appreciate the feed Back
One or two things you mention about the roof top i obviously didnt even consider, but certainly not a negative in my case,
Winches, understand your view on that , i guess thinking on that question it is more a peace of mind thing, seeing most of my travel will be solo, I have been caught with out one before and was a hard bit of recovery
Slamming with the links, will grab a coffee and start reading
Thank you so much
FollowupID: 807376
Follow Up By: Member - Scott M (NSW) - Thursday, Jan 30, 2014 at 23:38
Tony, in case anyone arc's up, I'm not saying winches aren't useful, just if I had a grand or two to spend a recovery gizmo, I'd opt for diff-locks before a winch. There's plenty of places I've been where I'd use a diff-lock before even considering a winch. Sand hills with no anchor points spring to mind...usually correct tyre pressure and diff-lockers will get you out of 95% of sticky situations
The levelling issue isn't a big issue, one of my friends carries a couple of those plastic tyre ramp thingy's for when he needs to level the vehicle - me - I just drive around until I find a flat spot.
"Needed" 4wd gear is one of those questions where you can ask 100 members here and get 100 different answers as to "what I wouldn't leave home without" - however stuff like good snatch straps, towing straps, shovels, good jacks, shackles, tyre repair kits, standard consumable spares like hoses / belts / globes / fuses / clamps / 100 mph tape / cable ties / sealant etc. etc. etc. are usually on everyones list.
Happy reading :-)
FollowupID: 807382
Follow Up By: Swaggee - Friday, Jan 31, 2014 at 12:56
*Tony, in case anyone arc's up, I'm not saying!winches!aren't useful, just if I had a grand or two to spend a recovery gizmo, I'd opt for diff-locks before a winch*
Hi Scott
Sorry i would have to totally disagree with your comment there mate, so what happens when his tyres are full of sticky clay mud and he is just spinning there on the spot, stuck in a bog hole etc... What are his options then...???
If he had a winch first there's a few more options available...More important recovery.
FollowupID: 807401
Follow Up By: Member - Scott M (NSW) - Friday, Jan 31, 2014 at 13:59
Swagee,
"stuck in a bog hole etc... What are his options then...??? "
Dig himself out?
Put some maxtrax or scrub / bushes down?
Avoid the bog hole in the 1st place?
Get another vehicle to snatch you out?
If you read my post....
"'m not saying!winches aren't useful, just if I had a grand or two to spend on a recovery gizmo, I'd opt for diff-locks before a winch"
As I said - my opinion - nothing more, nothing less...
FollowupID: 807410
Follow Up By: Swaggee - Friday, Jan 31, 2014 at 16:41
Dig himself out?
Nah mate a winch will usualy do just fine, sometimes you may need a double line pull...
With 2 lockers and maxtrax, what's that account too, roughly $3000
Plus $300 for two, you may need 4 and you could still be bogged. I not saying lockers are useless either but I've read plenty of posts where lockers were fitted firs, a lot say they got them deeper in the crap and without a winch they were stuffed..
A winch is around $800
So where's this magic vehicle come from when your out there alone which plenty of members do..
So i say a winch before lockers that's all, now to have all 3 you have most covered.
I'm not having a go at you at all its just my opinion too and not the end of the world.
Cheers.
FollowupID: 807426
Reply By: Kerry W (WA) - Friday, Jan 31, 2014 at 00:30
Hi Toney,
Your Question :- Which vehicle and set up to use.
My Opinion:-
In short - not towing a trailer is my preferred style gives you lots of freedom - depends on how adventurous you are.
Plenty of good info in the EO Articles eg "what to take"
Vehicle choice does come down to Patrol or Cruiser as "go anywhere" vehicles - some may argue this but in reality they do have a number of distinct edges.
80 series is the last of the really low maintenance high durability Cruisers. Personally I have a 2 seater GQ Patrol LWB (petrol) set up with a bed/kitchen/workshop in the back instead of the extra 5 seats. It is handy when you just want to stop and sleep. My choice/hanging onto of the older patrol stems from its reliability "field serviceability" and overall 4WD capability. (Plus the fact that I have maintained it extremely well) I have kept it because it seems unbreakable and I know it so well nothing catches me out, but primarily I dont enjoy the thought of re-fitting out another vehicle.
My point being.. any vehicle you buy an set up needs to be a passion and can become expensive to fit out the way you want it. If you choose a vehicle that you need to sell on in a few years much of your hard work and "passion" is lost, especially if you set it up properly for 1 trip - you will find you will want it to continue to do many trips into the future. It seems that the older cruisers and Patrols (Relatively low initial purchase cost) you can keep running (spend the $$s getting them the way you want) for many more years than some of the lighter duty 4X4s. My own experience is testament to that - also I live in outback WA and it is almost impossible to find a good 80 series or GQ or GU Patrol for sale as the owners keep them and just do them up. (Avoid the older 3 lit Diesel GU's at all costs though)
Petrol or Diesel? Many pros and cons with either but do consider replacement cost of engines and reliability of electrics.
Also it is worth noting...
Michelle and David (EO Owners and very adventurous!) still maintain the ExplorOz Landcruiser - a 1997 80 series GXL turbo Diesel as it is near impossible to find anything as reliable and capable for their purposes.
Just thought I would add these perspectives for you to consider.
Kerry W (Qld)
-Helen Keller
AnswerID: 525443
Reply By: shanegu6 - Friday, Jan 31, 2014 at 07:23
This post has been read by the moderation team and has been moderated due to a breach of The For Sale/Wanted to Buy Rule .
Forum Moderation Team
AnswerID: 525451
Reply By: Robin Miller - Friday, Jan 31, 2014 at 08:05
Lot of Solutions and a lot different senarios Tony.
There are a few things you left out of your post which would better define your position.
How many people - if only 1 or 2 you have more flexibility.
What sort of budget restrictions ?
Do you like to go seriously exploring - where there are no roads , no people and you need to be self reliant ?
Things like crossing Simpson are big touring trips these days - not actually exploring.
To handle the whole range of conditions we choose Nissan Patrol 4800 petrol in 2002 and have now owned several simply because we have found no vehicle to handle the whole range of senarios without peer.
Maximm flexibility means long range, lots of power , quiet for long distance touring , Petrol are generally easier to live with.
(Note pre hi-tech diesels like 4.2 patrol/80 series are just as good).
No fussy fuel technology and wide availability of accessories and availability of spares and relatively easy to service.
We sleep inside the car and don't tow anything so we can camp anywhere and take little space, and be on the move quickly.
Low cost of ownership - (this goes beyond fuel cost).
Many Cars and setups can do some of these things well - the trick is to do everything well and as with any engineering issue - better definition of your objective up front will lead to a better outcome.
AnswerID: 525452
Reply By: Member - John and Val - Friday, Jan 31, 2014 at 08:51
Hi Tony,
Have you considered getting a Troopcarrier? They have heaps of room and can go just about anywhere. Anyway, regardless of the type of vehicle you choose you might get a few ideas on set-up in this blog here that describes how we have set up our Troopie. Re fuel - we have never been seriously inconvenienced by having a petrol vehicle (and a fairly thirsty one at that) though in remote areas we have often carried extra fuel in jerrycans.
Val.
J and V
- Albert Einstein
AnswerID: 525456
Follow Up By: Toney - Friday, Jan 31, 2014 at 20:45
Hi Val.
Yes i have considered a Troopie, unfortunately they are few and far between here, either have very high mileage for the ones that have been fitted out or are just way too high in price, not saying a favorable one will not appear,
FollowupID: 807446
Reply By: Toney - Friday, Jan 31, 2014 at 08:59
To All that have replied so far, thank you. Certainly some worthy points to consider
I should how ever break things down, probably got over excited with my posting and the thought of the adventure and tried to cram too many questions in , breaking it down and starting for point 1 i think would be best , hopefully then a few things will fall into place
Firstly at this point there will be three people , me - myself and I ooopps 1 person (may be 2 so consideration has to be given)
Basically i will go for a roof top camper, i think this was a no brainer question being only 1-2 people but mainly asked to see what "negatives" are with these, Then just see which is the better of many that are out there or even "features"that may suit me better than others??
I guess the biggest peice of real estate is the Vehicle,
As mentioned I have owned an 80's ( 4" lift, snorkel,locker,12000 winch etc) and used it in some tough places ) sort of know the good and bad with this model, I regretted selling it, and the reason was fuel consumption, I guess i cant totaling blame the vehicle as i was born with a heavier right foot to my left, diet has solved this or was it age?? As mentioned in a previous post probably the last of the best models, How ever there is still a few about in my state, with 200-250k's and at quiet reasonable prices mainly petrol but quiet a few are duel fuel ( gas ) Why i also asked about the availability pf gas. The issue i can see also with this is, the aux tanks in the 80 os replaced with the LPG so extra fuel to me would be a must to have on board , then i can see another issue of where would u strap these tanks, especially if an additional spare wheel and roof top camper is fitted????
Seeing i had owned an 80 and liking the Patrols (GU) i was swaying towards them ( again some are well priced here) but then Kerry mentioned about "dont" i did a quick search and found some BIG issues realting the GU 1 and 2 models ??? Lookigng like a fix had been done on the 3 series and later?? ( obviosly there is more to the detail than i have typed, ie towing etc)
Also along my line of thought is, I dont want a Torak Tractor for highway touring, wanting a vehicle to be able to handle detours where and when ever i choice, and being my expectations exceeding my capabilities rather than the vehicle not being able to handle this, Again many factors i am sure come into consideration , ie tyres being one off the top of my head,
So a quick summary - vehicle choice
80 series - may be 100?? - Petrol - diesel - duel fuel
Patrol - GQ or GU ( this being the series 2/3 later)
On a note,
Seeing this is ( what i call) my first major Tour, even though it would be awesome to fully fit out a vehicle with every know option to man or woman. On a practical side of things, i would be looking at basic must have items to start with and add options as i go or on a need to have with some sort of trip planning, ( I will read thru the links that have been kindly provided )
Thank you all
AnswerID: 525457
Follow Up By: Robin Miller - Friday, Jan 31, 2014 at 10:54
Toney there are no issues with GU 4800 Patrol petrol your search revealed the issues with the 3lt diesels - quite a different beast.
Mine has 215lt of fuel which it needs as they use 1/3rd more than diesel.
Gas , well nearly fell over with price of gas in Vic - seen 112c recently compared to a 59c early last year , but for real exploring you don't want the complication of gas.
Roof top camper is interesting , personnaly I wouldn't travel in a top heavy car but if you like this then the GU again wins as it has 48 degree roll over angle, whereas troppies are sub 40 and 80 series about 45.
It does give you though plenty of extra room. While you can't take 3 people in our setup with double bed instead of passenger seats you could remove just one seat and use that for 3rd person.
Check out roof top campers carefully - I have had friends who have had to get theres re-done due to not enough room to fold up easierly resulting in wet beds etc.
FollowupID: 807391
Reply By: Member - VickiW - Friday, Jan 31, 2014 at 20:24
Hi Toney,
I'd pretty much agree with everything Scott said. On the winch option, particularly agree with the philosophy of avoiding the sticky situations if alone, lockers widen your practical options and maxtrax or similar are easier and safer to use than a winch. I carry a hand winch in the event I may get into a situation common sense & the above haven't worked. I really hope I never have to use it but if I do it will be more flexible than a bar mounted winch (although I may spend all day getting out of trouble !).
On the vehicle choice, I'd second Val's recommendation of a troopie or a newer 70 series.
Good luck & have fun!
AnswerID: 525531
Follow Up By: Member - Scott M (NSW) - Friday, Jan 31, 2014 at 21:31
Agree Vicki - on this topic I was only responding to Tony's planned itinery viz:
"I am intending to travel from Tasmania thru the centre to Darwin perhaps then to the cape ( if i can tag along with another group) or partial there, then back down the East Coast,"
and given that, I struggle to see where he would need a winch unless he's planning to go the OTT on his own. A hand winch if he wants some reassurance. Even lockers are a indulgence.
FollowupID: 807448
Reply By: Crusier 91 - Saturday, Feb 01, 2014 at 08:12
We have a 1991 80 series 4L petrol. The old girl is a beast and has never let us down in any of our travels. Having said that, she is maintained to the highest the degree and that dosnt come cheap but its peace of mind when in remote places.
Our perfect dream,
Patrol 4.2 common rail TD tray top with a full length box on the tray with doors on sides, 2 spares on the rear and a roof top tent on top is the best way to go when I go with the boys.
80 series factory TD with tail gate, dual tyre carrier, with camper trailer when the missus comes
A thorough check over of the vehicle by a mechanic prior to trip and get things fixed!!!!!!
Long range tanks in both, 100L water bladder, fridge slides, CB, as much recovery gear as you can afford!!!!!!!! Front and rear ARB air lockers are absolutely fantastic, they will may you look like a old 4wd pro. A 4wd training course wouldn't hurt either around $700 for 2. Check out 4wding gone wrong on youtube!
This can go on and on and on. We purchased our first 4x4 (80 series) for $8K thinking we'll just see how it goes, $28K later and still have many things on the wish list!!!!
AnswerID: 525552
Reply By: Member - Laurie K (WA) - Sunday, Feb 02, 2014 at 01:53
Hi Toney
I did my first trip in 2005, bought a 1999 HZJ105 diesel with barn doors (150K) - ex govt. I am its 3rd owner. It has now done 463K, was turboed at 290k and has spent the last 5 years towing a big caravan.
When I started, I travelled on my own, and for many years used a 2 man dome tent - quick and easy to set up, dry, and took no space. I bought a 7' roof rack to sleep on if I was in croc country (I knew nothing about them in those days) and I also had a swag to sleep in up there. Self inflating mattress.
I bought a good Compressor, a set of Staun deflaters, fitted a snorkel, UHF, changed all the belts and hoses, and kept the old ones as spares. I carried an extra spare wheel, and carried a couple of jerry cans of spare fuel.
I have travelled from Kalgoorlie to Coober Pedy via the railway line to Rawlinna, Connie Sue and Anne Beadell highways, with a fuel stop at Ilkurlka …… I used one of the Jerry cans so that I didn't run the tank dry, and found that I needn't have bothered. I've done Cape York, Dampier Peninsula, Gibb River Road and it's many side tracks ….. and never had a problem with obtaining fuel. Just fill your tank every time you get to a fuel outlet, and you will find it won't cost you a lot more, you aren't carrying all that extra weight. Take one Jerry Can at the most.
I've done part of the Simpson Desert (but not in real dry conditions I admit - wasn't my fault it was the wettest year at Birdsville in years in 2010 LOL). I have never in my 300k of driving this old girl had to resort to a winch, or been towed out of anything. If in doubt, don't go there, and believe me, I am an explorer. Tyre pressures will solve most problems, a shovel - I've never had to use mine -
Snatch straps, tow rope, a good hydraulic jack - that and the compressor have been my saviours. And a decent basic tool kit and Gaffa Tape, and WD40 ……..
Much of the stuff I bought, has never been unpacked. In fact, I unwrapped the snatch strap to tow someone else out of trouble 8 years after I bought it.
The fridge lives strapped to the back seat. Much less bounce and cushioned against shock.
Just a few thoughts …. basically keep it simple. And something else it took me years to find out - the passenger seat wound back was a damn sight more comfortable to sleep in when in lousy conditions, than trying to sleep across the hand brake and gear lever.
Just do it
Laurie
AnswerID: 525612
Reply By: Member - Laurie K (WA) - Sunday, Feb 02, 2014 at 01:54
Hi Toney
I did my first trip in 2005, bought a 1999 HZJ105 diesel with barn doors (150K) - ex govt - and NO electronics ….. I am its 3rd owner. It has now done 463K, was turboed at 290k and has spent the last 5 years towing a big caravan.
Just do it
Laurie
AnswerID: 525613
Follow Up By: Member - Laurie K (WA) - Sunday, Feb 02, 2014 at 01:57
Woops, sorry
That wasn't supposed to be submitted twice
Laurie
FollowupID: 807527
Reply By: Tony F8 - Sunday, Feb 02, 2014 at 08:18
Morning.
Laurie K pretty well summed it up, best to keep it simple, in any of the Moons guide books you will find a very good list of what to take.
I often found when doing the tags, clients would carry far to much of the unnecessary, they would carry the basic recovery gear, that wass not an option. Laurie mentioned a bottle jack, this should be included as standard, apart from it's lifting ability, they can also be used to push out panels in the unfortunate occurrence of pushing a body panel against a tyre.
Winches v Lockers, (a big can of worms and are two different applications), so I am not giving the following example to open up that can, but from personal expirience.
Creek crossing, entry bank was a reasonable decline and at the bottom looked firm, for the 15m to the creek, first vehicle broke the crust at about 12m and went down, stupidly the second vehicle came down, same thing at the 5 to7 m mark. Second vehicle had lockers and was going nowhere despite numerous attempts, the first vehicle had a winch and was able to winch out, then recovered the second. Without a winch, they would have been there for a long time just trying to get out. Don't rely on another vehicle coming along and if you can hook up to something with the winch, you will almost always get out.
And that your honor, is how the fight started.
Regards.
Tony F8
AnswerID: 525615
Reply By: Toney - Sunday, Feb 02, 2014 at 08:55
Some strong points have been stated in regards to lockers versus winches,
With respect to all perhaps we should kill this I have considered for's and against for both, and i think the winch has it for me over lockers .
A very worthy point too was keeping it simple i guess in a nut shell this basic rules applies to most things,
I am still arguing with myself over vehicle choice, Troopy i think is a no brainer here for reasons given earlier, Landcruiser 80-100 versus Patrol, Now i can also see sparks flying -) What would be a fairly true fuel consumptions figure;s Yes i know so many variable, But just an average/guess etc is all i am hoping for with this , ie 10l/100k 15l/100k or just ks to the tank,
Quick thoughts on the 2.8d turbo patrol. I have notice quiet a few of these available, Mainly with full reco engines and turbo;s plus drive train overhauls, Being specific ,mostly having 300k plus. I am assuming being the smaller and engine working harder etc etc, But are these a reliable engine/model ???
Txs - Tony
AnswerID: 525616
Follow Up By: Nutta - Sunday, Feb 02, 2014 at 21:59
The 2.8td patrols are a headache almost up there with the 3.0l td's, head problems and overheating being the biggest issues, stay away.
Cheers.
FollowupID: 807615
Follow Up By: Toney - Sunday, Feb 02, 2014 at 22:05
Thanks Nutta
FollowupID: 807616
Follow Up By: Kerry W (WA) - Tuesday, Feb 04, 2014 at 12:57
Hi Again Toney, The Diesel Patrol that you need seems to be a pre 2006 4.2 Turbo tray back - they are rare now because they are in demand.
Co Incidentally - My daughter recently scored a 2002 4.2TD Trayback (leaf rear springs new clutch 280k) for 15k. So far she has spent about 22k on it and it is excellent.
The smartest thing she did was to put on a 3" Superior Engineering lift kit (new everything inclucing bushes shackles and ball joints and 4 adjustable toughdog shocks.) cost approx 3-4k (trade) and ~33" tyres.
The reason I mention this is that she would have spent the extra for a coil cab for comfort but comparative price was 25-33k ... however as a tourer with a bit of gear always in the rear the firmer leaf springs are actually a bonus....the suspension job she researched and the adjustable shockies work very well. (I had the pleasure of driving it 4000klm from Qld to Wa towing a car on a car trailer and it was a dream to drive. btw averaged 16lit/100k with trailer at approx 100-110kph most of the way) Having lifted patrols previously I have to say Superior Engineering have got it down to a fine art and would suggest just spending the money to get a great ride.
If you do end up with a Patrol, from my experience I also suggest you investigate some Lokkas (lock rite auto unlocking diff locks) for the front diff. For the rear Diff simply use Penrites Limslip 140 (NOT 90/140) to ensure the LSD works to its maximum effectiveness. I cannot overstate how effective this particular product is for the Patrol rear LSD.
The Lokka should be under $500 Do a forum search for "Lokka" -- In short "reliable" - no air lines and compressors to fail. Also ability to actually turn in soft sand mud and on steep slippery slopes unlike most lockers. Just ensure they are installed "exactly" to spec.
Once installed - you will actually use them far more often than your winch.
I dont want to appear negative but..Remember Murphys Law dictates that some 4WD accessories (especially complex ones like winches and air lockers) work perfectly when out playing within 100k of home and will only malfunction in some remote location - when you really need them...
Kerry W (Qld)
-Helen Keller
FollowupID: 807736
Reply By: Toney - Wednesday, Feb 12, 2014 at 21:29
Just like ot thank everyone for replies and thoughts,
I have found a 93" Landcruiser in showroom condition with just 95000k.s, hoping i will not have to worry too much with reliabilty issue.
Now need to look at roof tents
AnswerID: 526312
