Van sandwich board
Submitted: Monday, Apr 21, 2014 at 20:53
ThreadID: 107391 Views:2402 Replies:2 FollowUps:0
Does any one know where I can buy van sandwich walls that do not need a frame. I think Jayco & Avan use them.
Reply By: Peter_n_Margaret - Monday, Apr 21, 2014 at 21:58
There are different qualities of sandwich panel. They are not all made equal.
The best are laid up wet on wet and then vacuum bagged using high density closed cell rigid polyurethane foam, NOT polystyrene.
I built the OKA MH body from sandwich panel 9 years ago. I purchased panel from 2 different manufacturers.
I recommend Vanglas in Yandina, Queensland for a quality product.
http://vanglass.homestead.com/
OKA196 Motorhome.
AnswerID: 530991
Reply By: Member - kev.h - Monday, Apr 21, 2014 at 22:13
Hi David
Google "composite panel or foam sandwich panel" you will find someone close to you who makes it most larger fiberglass outfits can supply panel
Kev
AnswerID: 530993
