Light Aircraft Wreck – Anne Beadell Highway
Submitted: Wednesday, Aug 06, 2014 at 08:10
ThreadID: 109040 Views:2667 Replies:4 FollowUps:2
I was just reading an informative thread, 108331, which has now archived.
A question was raised after I wrote about this aircraft recently on my website, and the inquiry was around why the owners were not required to remove the aircraft, as is often the case?
Not suggesting they should, or shouldn’t have, just whether there is any detail around that aspect.
Cheers, Baz – The Landy
Reply By: OBJ - Wednesday, Aug 06, 2014 at 08:20
It may not be the same answer in your case, but there is also a plane wreck not far from the homestead on the Trinidad station, out of Quilpie in Qld. The pilot was killed, but the 4 (?) mining engineers on board all survived. When I asked, I was told that becasue there were witnesses (survivors), they did not need to do all the forensic stuff. Pilot error.
OBJ
AnswerID: 537234
Reply By: Member - Terry W4 - Wednesday, Aug 06, 2014 at 09:07
There are many wrecks in remote and difficult locations. Once investigation complete is the property of the insurance company. I believe that they will not recover unless worth repairing./
AnswerID: 537236
Follow Up By: The Landy - Wednesday, Aug 06, 2014 at 12:27
Understand...
Although, perhaps in some cases they don't get a choice...
Cheers, Baz
FollowupID: 821523
Reply By: Member - Scott M (NSW) - Wednesday, Aug 06, 2014 at 12:29
"why the owners were not required to remove the aircraft, as is often the case?" - you could probably say the same thing about vehicle wrecks - ain't gonna happen.....
At least the road graders push them into the bush and burn the toxic materials out...
AnswerID: 537246
Follow Up By: The Landy - Wednesday, Aug 06, 2014 at 14:18
And in practice that may well be the case, but what if it is your private land and you don't want it there? There must be some requirements to cover this.
And I get it this aircraft is in the middle of no-where and most likely that no-one was too concerned about its removal.
Had me thinking after I was asked...
FollowupID: 821526
Reply By: passionfruit - Wednesday, Aug 06, 2014 at 17:54
Leave them there-------------I may need spare parts some day.
AnswerID: 537256
