Portable toilet
Submitted: Sunday, Sep 21, 2014 at 19:43
ThreadID: 109571 Views:3332 Replies:5 FollowUps:6
I purchased a 10 litre toilet a while ago but I am not sure if you are supposed to put water in the waste tank as well as the solution and if so how much water ? I gave never used one before
Reply By: peterdre - Sunday, Sep 21, 2014 at 20:37
Yep, in the waste tank I use about a cupful of water then add about 100 ml of blue, close it up and give it a swish around.
Pedro
AnswerID: 539369
Follow Up By: John S17 - Monday, Sep 22, 2014 at 05:27
Thanks peter
FollowupID: 823989
Follow Up By: John S17 - Monday, Sep 22, 2014 at 13:01
Hey peter how much water water for the rinse do u use ?
FollowupID: 824009
FollowupID: 824010
Follow Up By: peterdre - Monday, Sep 22, 2014 at 16:38
I presume you mean how much additive in the water in the rinse tank? I use about 100ml of additive to about half a tank of rinse water...I only half fill the rinse tank to keep the weight down. We only flush about 1 pump stroke when we use it. We only use the unit for no.1's.
FollowupID: 824020
Follow Up By: John S17 - Monday, Sep 22, 2014 at 19:08
Thanks pedro
FollowupID: 824027
Reply By: Member-Heather MG NSW - Monday, Sep 22, 2014 at 06:00
Instructions are written on the bottle or packet. Just follow those.
cheers,
Heather
AnswerID: 539382
Reply By: Member - Alan H (QLD) - Monday, Sep 22, 2014 at 06:59
No need for the chemicals --------
Use napisan or store product of similar name. Much cheaper and works fine.
Napisan is septic friendly etc while some of the "products" sold by toilet makers/sellers are not. Couple of tablespoons should be fine for 10 litres.
The other trick with toilets is to travel with them before emptying if possible as this ensures the contents are reduced to liquid for easy empting.
AnswerID: 539383
Reply By: Member - Odog - Monday, Sep 22, 2014 at 19:06
Hey John
Wife n I did a trip to wa few months ago, first time we had a toilet, we just filled the top tank with plain water, no additive. In the bottom holding tank, we put about 2 litres of water and one cap full of nappy san, only used home brand, as we were told it is better than leading brands. Just give it a good mix around before use...
So good... Never been excited about sitting on the loo before, just so much easier to have it in the corner of the camp trailer, we got a mate to make up an aluminium box, that the loo travels in on the draw bar. Clean, easy, and no smells.. No dramas... I'm all for the nappy san, give the chemicals a miss, they are no good if you have to dig a hole or dump it in a drop loo.. Way better for the environment ..
Cheers Odog
AnswerID: 539405
Follow Up By: Member - Peter H1 (NSW) - Tuesday, Sep 23, 2014 at 14:25
If you use the PP for only No 1's then napisan will not work.
It requires No 2's to get it going. Also needs to be agitated [drive with it] or again it does not work.
PeterH
FollowupID: 824057
Reply By: Motherhen - Wednesday, Sep 24, 2014 at 23:23
Hi John
My Blog on Toilet Chemicals and alternatives here has a summary of my comprehensive article on using cassette toilets.
AnswerID: 539501
