Phillips Vision Plus Globes
Submitted: Tuesday, Jan 20, 2015 at 01:16
ThreadID: 110813 Views:3088 Replies:4 FollowUps:5
Has anyone with a Landcruiser 100 series fitted “Phillips Vision Plus” globes, and is any wiring upgrade needed, or can you just put them straight into the light?
Reply By: Sand Man (SA) - Tuesday, Jan 20, 2015 at 07:38
I don't have a Cruiser, but I have used these globes in my previous vehicle, a Holden Jackaroo which had pretty ordinary lights.
No wiring upgrade is necessary as the current draw is the same as your current globes, (same wattage) so they are a straight swap for your existing ones.
Bill
AnswerID: 544606
Follow Up By: cobber - Tuesday, Jan 20, 2015 at 20:13
Thanks Sand Man
FollowupID: 831911
Follow Up By: Nomadic Navara - Wednesday, Jan 21, 2015 at 11:16
And if you upgrade the wiring you will get better performance again.
FollowupID: 831958
Reply By: Ando - Tuesday, Jan 20, 2015 at 11:51
Better to use Phillips "Blue Vision", I use these in all my vehicles, much better "white light" and no upgrade to wiring required.
AnswerID: 544619
Follow Up By: cobber - Tuesday, Jan 20, 2015 at 20:18
Thanks Ando.......Did you put them in the High and Low beam? Also where did you buy them, I have been to several outlets looking for phillips globes and non stock them!
FollowupID: 831914
Reply By: Ando - Wednesday, Jan 21, 2015 at 10:11
Have used "Blue Vision" or now called "White Vision" in all Headlights including Driving Lamps.
I'm in the trade and can purchase direct but you could try Repco, Supercheap or on Ebay.
Don't get sold on Narva bulbs as they are nowhere near as good. Remember most car manufacturers only use Philips or Osram branded globes as they are the best quality. (...what you pay for is what you get)
AnswerID: 544676
Follow Up By: garrycol - Wednesday, Jan 21, 2015 at 11:18
I have those globes in my car and really their performance is no different to "normal" halogen globes - in reality they are not noticeably "whiter" or "bluer" that normal halogens.
The ones I have are supposed to be 4200k and are supposed to be a close match to the 4300K HID globes I have in my low beam but the halogens are much yellower than 4200K probably closer to 3500K.
FollowupID: 831959
Follow Up By: Sigmund - Thursday, Jan 22, 2015 at 08:52
Autobarn usually also have a selection.
I have Repco and Narva brands fitted on high and low beam and they make a worthwhile difference.
FollowupID: 832013
Reply By: Member - Bookleaf - Thursday, Jan 22, 2015 at 22:51
I have Osrum "Night Breaker " (I think they are called) in my headlights. Came as a direct replacement to the existing lamp (high and low beam combined in one glass housing).
Much brighter and whiter light for the same wattage,
I got them a couple of years ago from England via Ebay.
Just have to keep the plastic lens on the headlight housing from yellowing all the time now to take full advantage of these new globes. (polish them up every now and again to remove the UV degradation of the lens.)
AnswerID: 544729
