Engel wires
Submitted: Sunday, Apr 05, 2015 at 21:10
ThreadID: 117355 Views:14300 Replies:4 FollowUps:1
I have a newish engel with a white & a black wire for the 12 volt plug. Which one is the active wire ?
Cheers Steve
Reply By: Member - Howard P (WA) - Monday, Apr 06, 2015 at 02:13
Not sure what colour wire is pos or neg, but just check the continuity with a multi meter and you will find out.
AnswerID: 552044
Reply By: Member - Tony F8 - Monday, Apr 06, 2015 at 06:30
If you unscrew the the socket type plug on the lead, the wire going to the centre pin is the pos wire.
AnswerID: 552045
Reply By: Sand Man (SA) - Monday, Apr 06, 2015 at 07:22
Even though my fridge is an earlier model, I would have thought the Engel lead is standard.
However, my lead has a twin figure 8 cable with two grey wires on the plug end, one with a red stripe on it, which is the active wire.
Are you changing the plug over to something else?
All connections on my lead are moulded plastic and cannot be re-terminated.
I cut the Engel plug off and replaced it with a Merit plug to suit my standardised method of 12 volt connections.
Bill
AnswerID: 552048
Reply By: Member - Phil G (SA) - Monday, Apr 06, 2015 at 09:50
White is pos. Black is earth.
The White pos wire sits under the white stripe on the outside of the lead.
AnswerID: 552051
Follow Up By: Member - Trouper (NSW) - Monday, Apr 06, 2015 at 10:57
Just as a matter of interest, I was given a set of halogen replacement lamps with the wiring harness and the Pos+ wire was white. which i thought was a little weird but a friendly Auto Elect told me that Toyota use white as Pos+
FollowupID: 837602
