Sticky Trailer Plug
Submitted: Monday, Apr 27, 2015 at 15:36
ThreadID: 117640 Views:2386 Replies:5 FollowUps:0
Hi All,
I have a 25mm diameter 7 pin trailer plug that is very difficult to take out, even when the locking catch is released. Does anyone have any suggestions of what I can use that will make it easier to remove without breaking anything - last time almost broke my hand!
Cheers Grant
Reply By: TomH - Monday, Apr 27, 2015 at 16:28
A bit of car cutter on the metal outside of the male portion should help.
Has anything damaged it.
They are better a bit tight rather than loose and falling out
AnswerID: 552986
Reply By: Frank P (NSW) - Monday, Apr 27, 2015 at 17:23
Periodically spray the pins, both plug and socket, with WD40.
AnswerID: 552989
Reply By: Bigfish - Monday, Apr 27, 2015 at 18:04
Try some fine wet and dry sandpaper to make sure everything is smooth. Then regular sprays of wd40 as suggested.
cheers If the plug on the car is metal, remove, dismantle and get to work with wet and dry on the inside.
AnswerID: 552992
Reply By: Sand Man (SA) - Monday, Apr 27, 2015 at 18:13
Replace either the 7 pin plug or the 7 pin socket, or both.
They are not all that expensive.
Bill
AnswerID: 552994
Reply By: Zippo - Monday, Apr 27, 2015 at 18:45
I personally wouldn't use WD40 - an oil-based water-dispersant - on there as you will attract a lot of dust which will compound the problem. Use a DRY lubricant (I use Selleys DriLube) and spray on the OUTSIDE of the plug body, not on the contacts as teflon is a v.good insulator.
AnswerID: 552996
