The product is supplied with three AAA Energizer Alkaline batteries and three AAA rechargeable batteries which are rechargeable after inserting via an included USB cable.
Looks to be a good quality headlamp. The triple power main LED spot light is super
bright.
Pressing the switch the first time will illuminate the main spot light. Holding the switch down will dim the beam until you reach the desired illumination level.
Pressing the switch briefly again, will turn the light off.
Pressing the switch briefly twice will active the two side LED lights, giving a wide beam flood light for cooking, etc..., in the dark.
Again, holding the switch down will dim the lights until the desired illumination level is obtained.
Pressing the switch again will turn the side lights off.
Pressing the switch for approximately two seconds or more will turn on the two red LED's for seeing in the dark without affecting one's night vision.
A brief press of the switch in any of the modes will turn that mode on or off without changing to another mode.
The head light is comfortable to wear providing illumination for
camping, fishing, or anything else you need to do while keeping your hands free for other tasks.
At full power you will get a 110 lumen super
bright spotlight which is quite
bright from such a small headlamp using 3 Alkaline batteries.
This will be a superior replacement for my aging Cree style headlamp and give more flexibility for a multitude of uses.
