New battery Charger - need some advice
Submitted: Monday, Jun 15, 2015 at 16:01
Lloyd M
My camper battery charger has failed, so I've just bought the Projector IC5000 unit to replace it. I have 3 X 120AH Fullriver batteries in the camper, are they AGM or Gel (after reading some threads on the
Forum I'm confused) ?
The new charger has several settings for different battery types, what should I set this one on as it will be hard wired in to charge these batteries only.
Any and all replies greatly received,
Lloyd Mac
Reply By: Racey - Monday, Jun 15, 2015 at 16:46
Hi Lloyd, Good choice for the charger, I use one too hard wired. Your batteries must have some markings, model number and/or type. If you can't identify the type, set the charger to "GEL" which will limit the charging voltage to 14.1V. The AGM setting will have a charging voltage of 14.4V.
Good luck with the identification.
Jon
555999
Reply By: Lloyd M - Monday, Jun 15, 2015 at 17:05
Thanks for your speedy reply Racey. My batteries are Fullriver DC120-12B
Lloyd Mac
556000
Follow Up By: Sand Man (SA) - Monday, Jun 15, 2015 at 18:12
Lloyd.
The batteries are AGM type. Good batteries. I run two DC105-12 batteries in my Camper.
See here for reference on yours:
Fullriver DC120-12b AGM Batytery
842093
