Pradopoint registration difficulties
Submitted: Monday, Oct 12, 2015 at 14:12
Amusong
Hi folks,
I am a member of this
forum but just bought a new Prado and was hoping to ask a few questions about towing/gear selection, on the Pradopoint
forum. Tried to register there but it is impossible. There is no way to contact them to even tell them there is a problem UNLESS you are registered. So there is no way I can tell them what is going on.
The specific problem is that there is a "random security question" you have to answer in order to complete your registration (presumably to prevent bots getting in). The question is "Surname of Australia's current Prime Minister".
Well I put in "Turnbull" but it says that is the wrong answer. Then, thinking it might be a bit out of date I tried "Abbot". Still wrong. Catch 22.... I went back as far as "Howard" just to make sure....but no luck. I was using a Mac computer.
My neighbour also has a Prado and he tried to register himself using and IBM PC. He got the identical "random" question (LOL....its not very random) and also failed to register.
So in desperation, having no other way to penetrate Pradopoint, I have turned to this
forum thinking that there will be many members of ExploreOz who are also members of Pradopoint. I would greatly appreciate it if someone out there could log on to Pradopoint and tell them that there is a problem with their registration system. I would be surprised if my neighbour and I are the only two people experiencing these difficulties.
Reply By: Member - Bruce and Di T (SA) - Monday, Oct 12, 2015 at 14:25
We have a Prado 150, automatic. We always tow in 4S not overdrive. We are also Pradopoint members. If you would like we could forward your post to the Admin team and see what happens.
Di
591499
Follow Up By: Amusong - Monday, Oct 12, 2015 at 14:44
Thanks - it would be great if you could let Pradopoint know about the registration difficulties. I would still like to join.
The actual question I have relates to the new 2.8 litre engine.
The new engine is coupled with a new 6 speed gearbox. I am aware of the idea and reasoning behind staying in S4 in a 5 speed gearbox but wanted to know how this might change with the new gearbox. Does one use the new S5? Or is S4 still the appropriate gear even in a 6 speed box. I believe the question has to do ultimately with transmission heat and transmission oil life. As I understand it S4 (in a 5 speed box) is a "locked gear" where the transmission is not so dependent upon the fluid coupling.
The Toyota handbook does not seem to cover this point .....at least I could not find it in there.
Tony
859543
Reply By: Member - Bruce and Di T (SA) - Monday, Oct 12, 2015 at 15:18
Tony,
Have sent your problem. I have also said I don't know your email address so if they reply to me I may
well have to post here.
Di
591501
Reply By: HKB Electronics - Monday, Oct 12, 2015 at 15:32
Previous priminister was Tony Abbott and it should work.
591503
Follow Up By: vk1dx - Monday, Oct 12, 2015 at 15:56
I even tried Julia without any success.
What a stupid question. It's like navigating by using movable objects as compass references references. No matter how smart the system is it would still need human intervention to make sure all is going okay.
859545
Reply By: vk1dx - Monday, Oct 12, 2015 at 16:40
Just enter Abbott.
Mine worked.
It wants the surname only and looks like they need to do some updating.
591504
Reply By: Member - Scott M (NSW) - Monday, Oct 12, 2015 at 16:51
One 'T' or two ??
591505
Follow Up By: TomH - Monday, Oct 12, 2015 at 21:04
Two B's Two T's one sugar.
859552
Follow Up By: Member - Scott M (NSW) - Tuesday, Oct 13, 2015 at 15:33
seems like I was right ...............
859575
Reply By: Stu & "Bob" - Monday, Oct 12, 2015 at 23:03
There is also Lcool.
Prado 150 Forum
591520
Reply By: Amusong - Tuesday, Oct 13, 2015 at 10:21
Well thanks everybody. The problem is solved - I could not spell Abbott as it turns out (thought there was only one t). I am now registered. Thanks for all your help. I will also register for Lcool and see what that has to offer.
By the way I contact
Tamworth City Toyota, who sold me the Prado, and they suggested that towing in S5 was the way to go (S4 where load/incline made it necessary).
Tony
591534
Reply By: Member - Bruce and Di T (SA) - Tuesday, Oct 13, 2015 at 17:26
Good as I have not had a reply from Admin @ Pradopoint.
Di
591555
