78 SERIES TROOPY POSSIBLE CLUTCH
Submitted: Monday, Dec 21, 2015 at 10:16
ThreadID: 131172 Views:3607 Replies:3 FollowUps:7
Hello all and what a great forum a wealth of information.
Ive got myself a troopy 78 series and have noticed oil leak coming from the bellhousing, at first it looks like transmission oil. As soon as I noticed that leak I am now getting slight vibrations while driving ie gear engaged (any gear), it goes away when the clutch pedal is pressed or in neutral. Sounds like it has something to do with the clutch. Was also thinking it might be the oil dribbling on the clutch itself that may also make this vibration. Ohhh almost forgot, there is also a small tapping noise like a bearing or something is warn out, once the car warms up a little, the noise and the vibration eases a little bit. Will have the mechanic look at it but that wont be till after the silly season is over. Your opinion, what could it be and roughly what am I looking at for the repair bill? Can I still drive it until it gets repaired or am I up for more damage?
Your thoughts appreciated.
Reply By: Bob Y. - Qld - Monday, Dec 21, 2015 at 10:51
A little more information might be handy, Troopi.
Year, kilometres, and engine, 1HZ, 1HD-FT or V8? How much oil is leaking from bell housing overnight? Is it tranny oil or engine oil.....they should look 'n smell different.
Have you checked the gearbox/transfer case oil levels since you bought it? Is the vibration at all speeds, in all gears? If it goes away when you depress the clutch, it sounds like transmission related.
We had an 80 series turbo that had a "tick, tick" noise in the engine. My wife could hear it, but I rarely could. Vehicle is still going as far as I know.
AnswerID: 594023
Follow Up By: Troopi - Monday, Dec 21, 2015 at 11:10
Hi Bob Y, thank you for the reply.
Sorry should have given the obvious info, well she is 2006 young, 193000kms 1HZ non turbo engine.
Definitely leaking from bell housing and its the transmission oil. Vibration is in all gears and only when under load ie, when accelerator pedal pressed, when I release the accelerator and still in gear the vibration stops. In terms of vibration it is only very light not heavy that rattles the car or anything.Vibrations stops when clutch is pressed in. The leak is only small at the moment, like a 3cm ring.
Last week the mechanic checked all the oils and were all OK, told him to also check diff oils and they were good too.
FollowupID: 862355
Follow Up By: Bob Y. - Qld - Monday, Dec 21, 2015 at 13:03
"Light vibration" would be par for the course on a troopy of that vintage & mileage, Troopi. :-)
The R151 gearbox behind the 1HZ are notoriously weak, but in all fairness, some seem to last much better than others. I'd also be checking items like rear pinion bearings for looseness, uni joints(need greasing, or binding ie: need replacing), t/case output shaft bearings, rear gearbox output shaft nut(inside t/case, possibly need tightening) and front driveshaft and diff. Front diffs are a bit weak, especially when they've been worked hard.
Are you driving around town with the front hubs locked in?
The oil leak doesn't sound too bad at this stage, but imagine it will contaminate the friction plate sooner or later. Do a bit of research on cost of replacement g'box/t'case unit(and clutch) as opposed to rebuilding your transmission. I replaced a g'box/t'case in an HJ60 some years back, cost $3800. Have seen similar(about $4K) for later model units, over past 12 months.
There are a number of blokes on this site who are far more qualified to comment than I am on your problem/s. They might help you in due course. In the meantime, just keep driving it......you probably don't have to worry till it starts making grinding noises. :-)
FollowupID: 862357
Follow Up By: Troopi - Monday, Dec 21, 2015 at 13:31
Thanks again Bob Y,
Probably wont need to go and change boxes just yet, will wait next week and see what the mechanic sais once he has a good look at it.
Dont have the hubs locked that's for sure, I do lock them and run for about 15-20 k's too lubricate front end if I have not been off-roading for a while. In the meantime I will check the rest of the items you mentioned above, never thought of that.
Now that I have noticed the leak I will also be checking the transmission oil level just to be safe it does not fall dangerously low (that's when the grinding starts).
FollowupID: 862358
Follow Up By: Frank P (NSW) - Monday, Dec 21, 2015 at 15:34
Could possibly be spigot bearing and/or input shaft bearing and seal.
FollowupID: 862364
Follow Up By: pop2jocem - Monday, Dec 21, 2015 at 16:47
If your troopy has less than 200,000 on the clock and considering the gearbox fitted to that vintage vehicle and the fact that the leaking transmission oil started about when you noticed the vibration I would say Frank would be pretty close with his guestimate. For the front seal on the input shaft to start leaking either the seal has just given up the ghost (unlikely for that milage) or the input bearing is getting a bit dodgy and allowing the shaft to drop. If the input shaft has dropped, the input shaft gears that mesh with the layshaft aren't in propper contact. If this is what is happening and you keep driving, particularly if giving it a bit of hard acceleration, the results could be a bit nasty cost wise. Not to mention leaving you stranded.
I would at very least drop the gearbox oil, have a good look at what comes out for any metalic particles and inspect the magnetic plug for bits that should be inside the gearbox.
Pop
FollowupID: 862367
Follow Up By: Troopi - Monday, Dec 21, 2015 at 17:42
Thanks pop2jocem.
I was hopeing it wasent that bad but to give you some history as to what may have caused either seal or bearings is the drive i did a few weeks ago from Rockhampton to Sydney, on the way down i got a tyre blow out at just under 100k.s the whole car shook violently thought the whole rear end had come off, this may have contributed in some ways i would imagine. Today i was driving it home from work about a 30 min drive i did notice a slight vibration and when it did happen i tested the clutch by pressing my foot down and the vibration went away released the clutch and it was back on. After about 2 min driving the vibration stopped and got home after that with no vibrations at all. I made sure not to over load it when the vibration kicked in but after it was gone it was fine just like a troopy should handle. I will take your advise and drop the oil and check it out for any metal probably tomorrow if i get time. Anyway got another car i can get to work in the meantime until the mechanic checks it out in the new year. Thanks for your input.
FollowupID: 862369
Follow Up By: Ron N - Monday, Dec 21, 2015 at 22:12
The vibration coming in when the clutch is released, shows the likely source as the gearbox input shaft (or clutch shaft, as it's sometimes called).
The greatest single source of problems and failures in Japanese gearboxes, is in the needle roller bearing that fits in the end of the input shaft, inside the gearbox.
The mainshaft fits into the input shaft here, and is supported by that needle roller bearing.
That needle roller bearing in most Japanese gearboxes is light duty - it operates with close tolerances, as far as needles-to-shaft clearances go - and it's generally the first bearing in the gearbox to fail.
When they start to fail, the mainshaft starts to jump around inside the gearbox, creating vibration - as the front end of the mainshaft is no longer held in position very securely.
The next thing that happens is the needle rollers start to break up and then they fall out and get mixed up with rotating teeth on the gears - and they get mixed up with the rotating balls and rollers in the other bearings.
By that stage, the gearbox is making LOTS of grinding and crunching and grating noises - and it's not long before you have total gearbox failure.
You can cheack on gearbox condition fairly easily by draining off a little gearbox oil when its cold.
Oil with a "silver paint look" is not a good sign and indicates failure is not far off, as there are many metal particles being shed.
Oil with tiny chunks of metal in it, shows that bearings have already started to fail in a big way, and that gearbox failure is going to happen, VERY shortly.
You can buy drain plugs that have a magnet built into them - these are very useful as an indicator of gearbox and diff condition.
Oil should basically be pretty clean and only slightly discoloured.
Badly discoloured oil, accompanied by a pungent burnt smell, indicates the oil has been running at too high a temperature, due to insufficient oil, or overloading coupled with high ambient temperatures - and this will harden seals and produce oil leaks.
Cheers, Ron.
FollowupID: 862377
Reply By: Life Member TourBoy, Bundaberg - Monday, Dec 21, 2015 at 16:15
Front uni on rear shaft or slip yolk play (under load), rear uni vibrates under decelleration
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 594033
Reply By: The Bantam - Wednesday, Dec 23, 2015 at 11:31
Oil leaking out of bell housing ........ bottom line, regardless of the actual cause, gearbox has to come off.
Not much point sweating about what might be the cause..... all this will be obvious when its all sitting on the ground.
Regardless you will be replacing the rear seal on the motor and the clutch ...... you just would.
I have to agree ..... its looking like that front shaft and its bearing & seal.
AnswerID: 594084
