Thursday, Dec 24, 2015 at 07:43
Having had both fridges in vans, here is what I have found.
The 12v compressor fridge does perform better as a whole over a wide external temperature range. The only down side is the battery side which many have covered.
The 3 way I have now is ok with the upside side being the use of gas while camped. No worries about solar performance due to cloud and It performs
well in moderate temperatures.
The down side is a couple of things. One, the 3 way takes a long while to pull things down after you go shopping. Two, you have to keep the van level while stopped. (within reason that is). Three, once the temp rises over 35C, the fridge struggles and that is for a T rated fridge.
I don't have a problem like Roachies with temp, as I have one of those Jaycar wireless temp monitors and I adjust the thermostat accordingly which keeps the fridge between 2 to 4 degrees.
Hope you both make the best choice for yourselves.
862451
