Great central road in October ?
Submitted: Wednesday, May 25, 2016 at 00:39
martine m
We are also planning to do the "great central road" in october
-does anyone know if the temprature is ok at that time?-
-doing it with a SUV be ok?
-are there possibilities to sleep along the way in road houses? campings?
Reply By: rocco2010 - Wednesday, May 25, 2016 at 11:37
Weather wise it most likely will be warm to hot.
the weather bureau records for
Warburton last October have one day with a max below 30, one above 40 and the rest in the mid to high 30s.
Not the time of year I would choose to be out there but it is great country.
600536
Follow Up By: martine m - Monday, May 30, 2016 at 22:07
thanks for your answer.....i understand......do you thinck that it is possible to sleep
in the vehicule with this temperature????
Martine
870102
Follow Up By: rocco2010 - Monday, May 30, 2016 at 23:36
Hi Martine
Obviously cooler at night. same records suggest temperatures in the high teens to low 20s. I doubt you would need a super sleeping bag wherever you sleep
870105
Reply By: Gramps - Wednesday, May 25, 2016 at 13:19
Reply By: Ron N - Wednesday, May 25, 2016 at 16:44
Martine - I've travelled along the GCR in late October. The temperature was regularly around 38 deg C.
Take plenty of
water - 5L a day for each person.
Warakurna is a very good place to stay,
Warburton is not so good, all the rest of the way there's only bare
camping areas with no facilities.
Warakurna has a store with food and
fuel, a motel, cheap "backpacker" accommodation, caravan sites, and campsites.
It also has a
camp kitchen where you can
cook your own food, and wash your utensils, and sit down in a fly-screened area to eat.
Warakurna Roadhouse
Tjukayirla has transportable unit type accomodation, back packer accommodation and caravan and campsites. It has a store with food and
fuel.
Tjukayirla Roadhouse
A SUV with adequate ground clearance is O.K. (minimum 180mm ground clearance).
There are often deep ruts in the road, and these ruts often contain rocks, so a very heavily loaded vehicle or a low clearance vehicle, will incur damage to the underbody,
fuel lines, brake lines,
fuel tanks, etc.
The road surface is corrugated (washboard) along most of its length, so steady driving is advised, not full highway speed. It's not difficult to keep up a steady 85-90kmh. About 40km in the centre of the GCR is sealed road of highway standard.
The Great Central Road
Regards, Ron.
600548
Reply By: martine m - Monday, May 30, 2016 at 21:41
thanks very much for kind answers
Martine
600757
Follow Up By: martine m - Monday, May 30, 2016 at 21:56
reading your answer i am wandering what do you mean
camping "with no facilities"? does it mean with no inside place to sleep, just an area where
you can
park your car and:or settle a tent?
also do you think it is possible to sleep inside the car by 38 degrees day:time
what is the difference with temperature night:time?
870101
Follow Up By: Ron N - Monday, May 30, 2016 at 23:33
Correct - "no facilities", means exactly as you describe.
Cars get very hot inside, even with windows down. It would not be comfortable sleeping inside the car in 38 deg C heat.
Pesky, annoying flies are also a problem, particularly after recent rain.
Night time temperatures in October in that area are moderate - 14 deg C is about the lowest you can expect overnight - 25 deg C is about the highest, overnight.
Around 20-21 deg C is the average overnight.
Here are the weather observations for
Giles Weather Station (at Warakurna) for October 2015. Maximum and minimum temperatures are on the left hand side.
Giles observations - Oct 2015
870104
