LPG bottle dust cap
Submitted: Saturday, Sep 17, 2016 at 16:07
ThreadID: 133458 Views:10451 Replies:13 FollowUps:13
Does anybody have any suggestions as to where one could purchase a plastic cap that screws into the POL fitting on my gas bottle? Managed to loose one and can't seem to find one at the major hardware stores. The cap keeps the dust out of the fitting whilst the bottle is not in use.
Reply By: Lindsaydi - Saturday, Sep 17, 2016 at 16:18
Have you tried the people who fill them??
AnswerID: 604467
Reply By: Tony F8 - Saturday, Sep 17, 2016 at 16:25
As said, anyone who fills gas bottles sells them, particularly camping shops.
AnswerID: 604468
Follow Up By: Allan B (Member, SunCoast) - Saturday, Sep 17, 2016 at 16:34
In fact I think the refillers are obliged to fit them when filling.
FollowupID: 874224
Follow Up By: Geoffr17 - Sunday, Sep 18, 2016 at 17:01
Yes Allan , in the article listed below by banksy69 it say's the refiller must fit the plug.
They got the customer to buy a plug ? . they should have supplied it.
FollowupID: 874258
Follow Up By: Shaker - Monday, Sep 19, 2016 at 18:59
So should a service station supply a fuel cap if you lose it?
FollowupID: 874283
Follow Up By: 9900Eagle - Monday, Sep 19, 2016 at 20:08
Don't know about the servo Shaker, but you could always ask to pay for one even though bcf just stick one in after a refill. It's my marbles I want them to replace for free.
FollowupID: 874286
Reply By: TomH - Saturday, Sep 17, 2016 at 16:59
Its because they come loose that you LOSE them. They come with a retainer strap on them usually.
AnswerID: 604470
Reply By: GarryR - Saturday, Sep 17, 2016 at 17:28
try BCF that's where I got mine last year
location - Warragul -Victoria
AnswerID: 604471
Reply By: Peter_n_Margaret - Saturday, Sep 17, 2016 at 19:23
I modified a couple of old POL brass male fittings. Added a short chain attached to the bottle.
AnswerID: 604476
Follow Up By: vk1dx - Sunday, Sep 18, 2016 at 12:15
Exactly. And if you don't have any in the back of the garage go to the recovery mob at the rubbish tip or wherever you state/council allow it and get some that were tossed out. Recyclers is a better word for them.
FollowupID: 874246
Reply By: Member - ACD 1 - Saturday, Sep 17, 2016 at 19:45
Search for Gas cylinder valve safety plug. They are available from CAMEC and Caravans Plus for less than $10. Have also seen them at BCF, Ray's Getaway, Kmart etc in a 2 piece blister pac.
Model available from CAMEC
MOdel available from Caravans Plus
Anthony
AnswerID: 604477
Follow Up By: Member - ACD 1 - Saturday, Sep 17, 2016 at 19:49
Forgot to add...
I drill a small hole through the handle and add a piec of nylon string to tie around the cylinder valve. If it comes loose, it doesn't get lost.
Anthony
FollowupID: 874231
Reply By: banksy 69 - Sunday, Sep 18, 2016 at 06:33
I often have a chuckle about those cheap plastic plugs,
LPG at 54 deg exerts a force of 1794 kpa.
They should be brass with an oring.
AnswerID: 604483
Follow Up By: Sigmund - Sunday, Sep 18, 2016 at 08:12
Only intended to keep the dust out.
They don't last in UV light either so turn brittle and break.
FollowupID: 874235
Follow Up By: Member - Ups and Downs - Sunday, Sep 18, 2016 at 08:47
It must be a Qld thing. I have never even seen one in the West.
Not on portable, or on larger household cylinders.
Paul
FollowupID: 874237
Follow Up By: Peter_n_Margaret - Sunday, Sep 18, 2016 at 08:48
Useful to keep wasps and the like out too.
FollowupID: 874238
Follow Up By: Sigmund - Sunday, Sep 18, 2016 at 10:56
@banksy. Interesting. I gather in some states you can't carry gas bottles in a vehicle at all.
FollowupID: 874242
Follow Up By: Frank P (NSW) - Sunday, Sep 18, 2016 at 14:50
I think Sigmund is on the money - it's a Queensland thing. When I had a bottle refilled up there a while ago I was told that Qld regs said I had to have a plug, which I didn't at the time. They sold me one for a dollar and said every filling station would do the same if needed.
Never had anyone worry about it in any other state.
FollowupID: 874252
Reply By: The Bantam - Sunday, Sep 18, 2016 at 11:07
Seems everything has got cheap and nasty ..... and they still want to hit you up top dollar.
Some years ago it was possible to buy a fairly decent plastic screw in bung with a decent knurled knob that you could get decent a hand full of ... and they came with a piece of chain attached.
Now as has been mentioned the swap and go gas refillers are required to fit one every time they fill a bottle.
The bungs they use will probably cost them 50cents or less as they consider them disposable.
AnswerID: 604489
Reply By: Member - Gary R M (VIC) - Sunday, Sep 18, 2016 at 11:37
Champagne corks work ok.
Once you've emptied the bottle of course.
Cheers, Gary M.
Gary M
AnswerID: 604490
Reply By: oetkb - Sunday, Sep 18, 2016 at 18:55
Buy a role of masking or electrical tape and use that.
AnswerID: 604498
Reply By: Malcom M - Monday, Sep 19, 2016 at 07:43
Anaconda ad Gameco both sell them
AnswerID: 604506
Follow Up By: Member - rondesron - Tuesday, Sep 20, 2016 at 20:58
Thanks got them at anaconda
FollowupID: 874308
Reply By: Cybermike - Tuesday, Sep 20, 2016 at 14:39
My small bottle (about 3kg) has a POL with threads on the outside - which holds nicely a chair rubber end cap e.g. https://www.bunnings.com.au/tic-10mm-round-white-rubber-external-chair-tip-4-piece_p4050056 I'm not sure if all POLs are the same size, & not sure what size cap I bought - though there are plenty available & in black or white.
AnswerID: 604530
Reply By: Member - Scott M (NSW) - Wednesday, Sep 21, 2016 at 19:30
Gas plug - pick them up at Bunnings for bugger all - no thread - just push them in - never had one fall out.
AnswerID: 604560
