Knife Handle.
Submitted: Thursday, Dec 22, 2016 at 18:35
Hi I have a great craving knife which was droped and the plastic handle on one side fell off and need to be glued back on any ideas on the best glue .John .
Reply By: lancie49 - Thursday, Dec 22, 2016 at 19:07
Reply By: Member - Stephen L (Clare SA) - Thursday, Dec 22, 2016 at 21:33
Hi 2517
What about liquid nails. Once it has set, you will never get the handle off.
606898
Follow Up By: 2517. - Friday, Dec 23, 2016 at 07:38
Thanks for that.
876621
Reply By: Idler Chris - Thursday, Dec 22, 2016 at 22:47
Reply By: MUZBRY- Life member(Vic) - Friday, Dec 23, 2016 at 08:02
Gday
What's a craving knife?
606903
Follow Up By: Member - Wildmax - Friday, Dec 23, 2016 at 08:34
It's the knife you use when you get a craving for a slice of cake in the middle of the night !!
| Wildmax
Formerly an AOR Eclipse and a TVanMember My Profile Send Message |
876624
Follow Up By: RMD - Friday, Dec 23, 2016 at 14:46
I wondered about it being "droped".
I suppose you drope everything when craving.
876635
Reply By: Neil & Pauline - Friday, Dec 23, 2016 at 09:45
polyuathane aquadere glue. Make sure it is not pva,
I will bubble up out of join for a while but dont wipe it off, wait for it to dry and trim with a knife. Needs 24 hours to set and needs to be clamped. Don't glue clamp to the job. I use news paper between clamp and job. There are easier products to use but nothing better.
Neil
606908
Reply By: 9900Eagle - Friday, Dec 23, 2016 at 10:28
John, Devcon have an excellent product that I have used many times. It is called Plastic Welder and is good for bonding hard plastic, concrete, metal and so on. It is similar to epoxy and you can buy it at Blackwoods, RS online in a 25mil 2 part injector syringe style package.
Hers is a
LINK to what the product looks like and it's specs
606911
Reply By: Sand Man (SA) - Friday, Dec 23, 2016 at 12:50
Nobody has mentioned the old trusty favorite so I will.
Selley's Araldite, a two part epoxy adhesive. It can be purchased in small sized tubes or a double syringe type container.
Use the "original" araldite, not the 5 minute one.
Lightly clamp or tape to stop handle from sliding and leave for 24 hours.
If the handle (which you say is plastic) was heat proof, you could have placed in a moderately hot oven and cured the adhesive in 1 hour.
606920
Reply By: Wayne B16 - Sunday, Dec 25, 2016 at 12:01
Araldite the slow curing one
606967
