BATHURST TO WINDSOR
Submitted: Friday, Jul 06, 2018 at 09:09
ThreadID: 136943 Views:5211 Replies:6 FollowUps:8
Which is the best road from Bathurst to Windsor. Towing a 21ft van. Great western hwy or Bells line. Cheers
Reply By: Kevin S - Life Member (QLD) - Friday, Jul 06, 2018 at 09:15
I think Bells Line is a better drive as you miss all the Blue Mountain towns along the GWH. I think the road out of Lithgow is an easier climb than Victoria Pass, although I have not towed the caravan up either.
Cheers, Kevin
Kevin
2019 Mitsubishi Cross
AnswerID: 619972
Follow Up By: Glenn C5 - Friday, Jul 06, 2018 at 09:59
Thanks Kev
FollowupID: 892306
Reply By: Rangiephil - Friday, Jul 06, 2018 at 09:49
Well I think that the main highway via Mt Victoria is better. Once you are over Mt Victoria it is basically downhill all the way and 4 lanes for most of the way.
The Bells Line has many 2 lane stretches and lots of steep sharp hills , some with climbing lanes which abruptly end.
There are far more hairpins on the Bells Line particularly down Kurrajong Heights where you will have a long tailback and many pushing to pass. There is one particular RH corner which has a double lane which then turns to single where many will try and push past you.
Once down on the highway , you can go F4 then onto F7 to Windsor, whereas with the Bells you will need to go through Richmond.
Regards Philip A
AnswerID: 619973
Follow Up By: Glenn C5 - Friday, Jul 06, 2018 at 10:00
Thanks Phil
FollowupID: 892307
Follow Up By: Nomadic Navara - Friday, Jul 06, 2018 at 20:07
Phil, it sounds like I could easily get you lost in Sydney. This is the way you are suggesting to go from the foot of the mountains.This is the way I would go. the route is 15 km less.
FollowupID: 892324
Follow Up By: Rangiephil - Friday, Jul 06, 2018 at 20:25
The easy way to go is M4/M7.
110 then 100Kmh all the way with only one intersection "The Light Horse"
The roads are straight with no hills unlike the other way.
I have only been that way a couple of times quite a while ago but it is through suburbs and has high traffic.
Once you get off the M7 it is also 80Kmh either 6 lane or 4 lane along Windsor Rd through Kellyville , Rouse hill etc. although there will be a lot of traffic.
Just avoid Saturday morning as that is the heaviest traffic of all due to kid's sports .
FollowupID: 892325
Follow Up By: Michael H9 - Friday, Jul 06, 2018 at 20:34
Why would you go anywhere near the M7 to get from Bathurst to Windsor?
FollowupID: 892327
Follow Up By: Nomadic Navara - Friday, Jul 06, 2018 at 21:05
Phil, you go this way do you? That's even longer than the one I thought you meant (5 km or 8 minutes.)
Michael, I am wondering that too. Why would travel 27 km and 13 minutes extra to travel the same journey plus spend $7.20 in tolls. As to the "The roads are straight with no hills unlike the other way," I don't know here the hills are. Maybe he is referring to the bridge over the western railway line as a hill.
FollowupID: 892330
Reply By: Member - William B (The Shire) - Friday, Jul 06, 2018 at 10:29
Hi Glenn C5,
For me the time and day of travel would be a factor.
Great Western hwy. can be a pita weekends and early or late in the day, just my observations of going that way over the years.
The road works seem to have settled down a bit, but beware of the changing road speeds, they do my head in.
Victoria Pass is a climb put once you are up its not too bad.
William
AnswerID: 619977
Reply By: splits - Friday, Jul 06, 2018 at 19:02
With a 21 ft van behind me I would choose the highway any day even in peak hour traffic.
My first trip over Bells Line of Road was in October 1963. The last was in February this year. There has been a few hundred in between those two dates. It was on the last trip that I decided I would not do it again. There was noticeably more traffic on it. The speeds of other cars seemed to be higher but the road was just as narrow and winding. For the first time ever I did not enjoy it.
I was driving a 4x4 Hilux which is no sports car. Neither is any other car with a big van behind it. I often had a long line of cars behind me.
In April this year I made yet another trip back through Bathurst but this time it was via Victoria Pass. It was a lot more relaxing. There was even more traffic and some road works but if you just follow the car in front and forget about overtaking or time limits, it is as easy as can be.
Crawling up Victoria Pass should not be a problem and coming down off the mountain is about 1000% easier than descending Kurrajong Heights.
AnswerID: 619997
Follow Up By: Baz - The Landy - Saturday, Jul 07, 2018 at 07:43
Hi Glenn
I'm with "Splits" on this.
Having travelled the Bells Line of Road countless times over just as many countless years, I would take the Highway down through Katoomba if you want a less stressful drive.
It is out of your way, but the problem with the Bells Line of Road towing a van is that you'll have other vehicles "shunting" you along all the way, and not a lot of passing opportunities.
Time wise, it won't add a lot of additional time...
If towing we always go the Highway via Katoomba.
Enjoy,
Cheers, Baz - The Landy
FollowupID: 892342
Reply By: Nomadic Navara - Friday, Jul 06, 2018 at 20:28
Both Scenic Hill and Mt Victoria pass have 1 i8 maximum gradients so they are much the same. Bell's Line of Road also has a second 1 in 8 ascent at Mt Tomah.
Bells Line of Road does not much have in the way of roadside rest areas. The highway has a couple of good ones, Sutton park just after Blackheath and Bulls Camp after Woodford.
I have been travelling these road sine the 50s (before Bell's was sealed.) If I am in a hurry and don't mind a challenge I use Bell's. If I want a more relaxes trip I use the highway.
AnswerID: 620002
Reply By: Gronk - Saturday, Jul 07, 2018 at 18:25
From Bathurst, you go thru Lithgow either way.....from there to Windsor I would always go via Bells. One little steep hill out of Lithgow and pretty easy going the rest of the way.
For me , on the central coast, it might be easier to go the M4 and the M7, but not if I had to go to Windsor !!
AnswerID: 620027
Follow Up By: Glenn C5 - Monday, Jul 09, 2018 at 09:14
Thanks all for your help. Prob take the highway. Cheers Glenn
FollowupID: 892373
