Cahills Crossing Arnhem Land
Submitted: Sunday, Jul 20, 2025 at 11:53
ThreadID: 151091 Views:2443 Replies:5 FollowUps:3
When researching a recent trip all data and reports about Cahills were quite frankly sensationalised and not particularly helpful. Yes if you are an idiot you can get into trouble.
Yes there are reasonably accurate Tide charts, BUT there was nothing that helped me interpret what does a .75m Low actually mean for water "over the causeway". The "answer" was about 300mm!! It was a total non event as we crossed right on the low. If the "low" was say 1.5m, it would be much more challenging!
The Blyth River crossing was tougher!
Reply By: Member - LeighW - Sunday, Jul 20, 2025 at 13:09
It's not just the depth, its how fast the water is flowing. Doesn't take much depth to get you trouble if its flowing fast enough.
Agree though, tidal charts aren't much good if you can't relate that to crossing depth. We did same as you waited till low tide and it wasn't a problem. Coming back we arrived when we did and depth was about 500mm and flowing quite quickly which required more consideration.
AnswerID: 648304
Reply By: Allan B (Sunshine Coast) - Sunday, Jul 20, 2025 at 14:54
Hi Ken,
Where is the sign that states " .75m Low " at the crossing and is that exactly how it reads or are there more words?
I know there are signs atop the depth marker boards that say "Indicates Deepest Point" but I have not seen the sign you refer to.
AnswerID: 648305
Follow Up By: Member - LeighW - Sunday, Jul 20, 2025 at 15:24
He is referring to the Tidal predication table high and low. The problem is how does this relate to the crossing, the crossing level will be dependent on the tide level and the amount of water flowing down the river.
FollowupID: 929584
Follow Up By: Allan B (Sunshine Coast) - Sunday, Jul 20, 2025 at 15:53
Ah yes, thanks Leigh. Somehow I imagined that Ken was referring to a sign at the crossing.
Yes, of course the the charts would be referencing a nominated location on the East Alligator River but that would only help ascertaining when the level at the crossing would be at its lowest, not the actual level. The tide information may assist a person to plan a crossing time then observe the depth indicator boards when they arrive.
The other often employed method is to just rack-up anytime and take a break while watching others cross before taking the plunge, errr, so to speak.
FollowupID: 929585
Follow Up By: Member - Happy Explorer - Monday, Jul 21, 2025 at 08:00
Hi Allan
That is an interesting point. Tide times and heights taken somewhere else still need local knowledge to interpret, as you suggest it "may assist a person to plan ..."
Many years ago we spent a couple years living on our yacht at Maryborough Qld. Tide information was quoted at River Heads somewhere I think (doesn't really matter). The thing is, we knew how many hours difference there was between what was quoted and what happened in reality at both high and low tides at Maryborough so far up stream. An interesting quirk was that high and low water did not coincide with the change in current.
This was problematic for several yachties like us with deep draft vessels who wanted to use a local slipway. We needed the highest point on the tide (and a king tide at that) but by then the current was already running out quite strongly. Quite a trick holding a large yacht at right angles to the current and lining up with the slip. Probably easy for a twin screw motorboat with a bow thruster.
Just saying that tidal rivers need local information to know what to expect at any given point.
I think your last point is safest, 'observe and wait'.
Roy G
Toowoomba (now on the road full time)
FollowupID: 929587
Reply By: Member - McLaren3030 - Monday, Jul 21, 2025 at 07:42
The thing to remember is that the tide height is measured on the down stream side of the crossing, and may not represent the depth of water over the crossing. The depth of the water over the crossing is determined more by the volume of water coming down the river. Of course, with a high tide, and a high volume of water coming down the river, the depth over the crossing could be impassable.
I am not sure if there is a web site showing live data of the water volume flowing over Cahills Crossing. Many other rivers have this data available.
AnswerID: 648307
Reply By: Member - LeighW - Monday, Jul 21, 2025 at 09:05
Here is some intersting reading on the crossing.
How and when to safely cross Cahills Crossing
And here is a link to the Cahills crossing tide time:
Cahills crossing tide times
AnswerID: 648308
Reply By: Batt's - Monday, Jul 21, 2025 at 10:18
.A non event would be better than a more challenging 1.5mtr a person would be stupid to be looking for a challenge on that crossing or any other northern river crossing. But as humans are there have been some attempt it even on foot with dire results.
AnswerID: 648310
