I had a similar issue of intermittent dropping off and needed to reboot, very frustrating
I narrowed it down, not to a power issue but the USB cable must have had a microscopic fault in it and as soon as it transferred power & data it must have caused a separation in one of the wires causing separation and thus dropping out.
Your talking microns as far as size goes in the fault and also microscopic measurements in heat buildup with data transfer. Either way that was the issue.
I changed out a few USB cables to no effect, noting that some USB cables are power supply only and others are power & data but not all of sufficient specs to transfer the data
I proved it by using a USB cable from a hard drive (that was obviously
well over specs to supply the hard drive) and all worked perfectly.
Sometimes the most frustrating issues are caused the simplest things and the hardest to narrow down.
649190
